Question about Gestetner DSM 651 Copier
Dsm651sp Paper keeps getting stuck in the B1 area. When I take it out the same thing happens as soon as the door closes.
  • 24 Answers
Repalce the pick up rollers,paper feed rollers, seperation rollers of the trays which gives the pper jam
Posted on Oct 22, 2007
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
GMC Envoy 2004 XUV tailgate won't latch closed. Pressure switch makes latch click but when I go to close it, it does not latch.
Two things happen. One the latch is already latched and therefore it's closed before the gate shut, When you try to close it you might notice that the door don't close all the way. This doe'snt have to be thwe case. the other thing that happens if the lock mechanism is working, You here it click? The latch is stuck as the opener is stuck. You might get lucky and spray the latch with Blaster or other rust buster type penatrant. Theres angles though the opening of the latch . Spray on several angles and repleatly close the door trying to vibrate the Penatrant into the stuck area. Looking at the latch use a screw driver to move the latch and see if you can cycle it though it's positions to see if you can latch and unlatch it with the tool and reopen by pullung the handle ( you may need to try ther inside handle too and even the remote openner if you have one. Ussaaaly you need to push the button twice to open the rear hatch so it may take a few trys and spraying to get it to come loose.. Some vehicals stay closed a long time and stuck is the way to think.. But if the door is used often the linkage inside the door mayh have come off the the latch is closed and the linkage doesn't open the laTCH AND THE THING MANAGED TO GET CLOSED WITHT THE DOOR OPEN.
May 09, 2011 | 2004 GMC Envoy
202 PAPER JAM OPEN REAR DOOR, CLEARED THE PAPER BUT STILL GETTING THIS MESSAGE
Turn off and back on. If the error is still there, look in different areas of the printer, somewhere there is a piece of paper stuck. Sometimes when clearing a jam, little pieces will get stuck in the rollers and you just need to search for them and remove them to clear the sensors.
Mar 16, 2011 | Lexmark Office Equipment & Supplies
1996 Rav: Driver side door will not shut in cold weather, requiring me to hold the door closed while I am driving. Once vehicle warms up, door will shut. Very Very frustrating, when driving a short...
You have water in the latch mechanism. To solve the problem apply heat to the latch area of the door. I use a propane torch but a hair dryer or heat gun will also work. They will take longer though. Be careful with the torch so you don't burn the paint. hold it fairly close but keep it moving constantly. You will see the paint change appearance when you start to apply heat, keep heating until it changes back. At that point the latch will work. Close and open the door a few times and it should keep working for a while. The best thing to do is spray it with some WD-40 or RustCheck as soon as you get it working. Put the nozzle on the can and bend it right into the latch and spray around heavily. This should keep it from freezing up again. Hope this helps.
Feb 22, 2011 | Toyota RAV4 Cars & Trucks
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
Keepes saying paper jammed but there no paper stuck
Turn off the Printer
Remove the Rear Access door
Check for any bits of paper stuck in the rollers
Clean the Rollers with lint free cloth ( upward exactly how the paper rollers)
Open the Front access Door, Check for any paper stuck.
Close the doors and try to turn on the printer
If this does not work, Disconnect the power cord from back of printer when printer is powered on.
While holding the OK and Cancel button connect the cord back.
Jun 23, 2010 | HP Photosmart 4180 All-in-One Printer
Brother MFC 8220 -- paper keeps getting stuck in the drum. Replaced drum but still happening. Makes a loud noise when trying to print.
sounds to me like your fuser gear has broken. look for your exit rollers. they're right where your paper exits the machine. while watching them closely, open door, then close so that machine goes through its little warmup. if you don't see those rollers turning, chances are very good that your gear has broke.
hth,
razors
Feb 01, 2010 | Brother MFC 8220 All-In-One Laser Printer
At power on I get a 13.20.00 jam inside rear door. Nothing is found in the rear door area. I can't find any flag tied up or a sensor to clean.
This error can be misleading at times. Although it says to check the rear, if you haven't already, remove the toner cartridge and check inside. Also, when you look inside you should see a green lever on the right side. Lift that and check to see if there is paper stuck down there. Another place you can look is in the paper tray area. Remove the paper tray and check to see if there is a piece caught on the way up. Keep in mind when removing a jam make sure you get a whole piece of paper, any missing pieces will cause problems later.
If both areas appear to be clear, think back to if you have a paper jam and got the paper out. Did the paper tear? A small piece could be stuck on a sensor within the printer. If you find paper and everything is good to go, check the pick up rollers to ensure jamming won't happen again. They are located on the paper tray (grey/blue roller) they should like mini tires with grooves, NOT smooth. The other roller is located inside the printer.
Mar 26, 2009 | HP LaserJet 4200 Printer
Paper detection
The same thing happened to me once. Try looking near the cartridges and where you input the paper, there might be an item stuck which makes it hard to print or load the paper. When that happened to me, i noticed that there was a pencil stuck in mine. I ended taking it all apart in the end, but that is only because someone forced it in there. In the end, it worked!
Hope you get your working soon! =]
Aug 27, 2008 | Lexmark Z735 InkJet Printer
Paper jam
Introduction
The flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
Instructions
Difficulty: Moderate Steps
1 Step One Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2Step Two Turn off the printer.
3Step Three Remove any paper trays. Inspect them for wrinkled or damaged paper.
4Step Four Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5Step Five If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6Step Six Click to enlargeIf you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. SEE PICS http://www.imagehost.ro/pict/0104361047293b9a4006c.jpg
7Step Seven Click to enlargeIf the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.SEE PICS http://www.imagehost.ro/pict/0104365847293bcaa9870.jpg
8Step Eight Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9Step Nine If the printer paper jam message still appears, then there is still some paper in the printer.
Reinspect the paper path.
Nov 02, 2007 | HP DeskJet 3325 InkJet Printer
Gestetner DSM 651 Copier Logo
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
