Blades need to be cleaned. How do I do this?
Press the reverse switch if the reverse switch does not work it is a case of removing the power then getting a small hook such as the ones used for needlework and picking out the jam
If it still wont run then it is a complete strip down job.
Depending on the cost of the shredder it is cheaper to replace the small home ones than it is to repair them.
Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
