Question about Sharp AL 1631 Copier
I have an L4 mesage blinking on my copier(AL-1631). Is there anything I need to know what to do? Eddie Porter
  • edporter May 29, 2009
    Would it need a new drum? There is toner on the existing drum along with sone streaks
  • 313 Answers
L4 is usually to do with the main motor drive check the papaer path from tray to exit to see if there is any jams then take the drum out amd manually turn the gear to see if its stiff the last place to look is the fuser check from exit if the rollers are jammed ort there is an obstruction.
Posted on Jun 11, 2009
    Sniper:
  • 67 Answers
Not a direct solution but maybe this link will help:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Posted on May 29, 2009
  • Joe Hidden May 29, 2009
    normaly the L4 points to a motor problem. but reading about streaks on the drum, the drum might be also part of the problem (like blocking motion)
  • 32 Answers
If your only problem is L4, please check the main motor. It might be defective. Try simulation 25. Press C, exposure key, C, then enter 25 and press Print key, then check your main motor if it rotates or function....
Posted on Jul 17, 2009
    President:
  • Sharp Master
  • 1,447 Answers
Yes it is the problem your copier machanical or main motor chack it and solve it
Posted on Jun 16, 2009
  • Sazeed Computer
    Sazeed Computer Jun 28, 2009
    your copier is the problem fuser unite jum
AL 1631 Grayscale Copier: letter h is blinking in the display unit does not ...
all the codes with(H4,H3,.......)can be removed by simulation 14
May 16, 2010 | Sharp AL 1631 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
LED flashing an "L"
L1 Mean scanner problem.
Solve: If you lock scanner please unlock.
L4 Mean Main motor or any Gear slug.
Solve:Please check motor section in your copier any kinds of Gear was broken.
Jan 13, 2010 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
H4 problems
Try to reset the error code by pressing : C exp1 C exp1 14 start. if the problem still occur then you should change the heater lamp
Apr 01, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Drum Icon only blinking
Hello sir; After install drum unit you need to reset, the procedure as follow;
1, press "#", "*", "clear", "*",keys.
2, enter 24 press start enter 07 press start.
3, turn power off and back on.
Jan 31, 2009 | Sharp AL 1631 Copier
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Dec 24, 2008 | Sharp AL 1631 Copier
L 1 blinking
you cant fix this. because scaner is brooken . it will need new parts. call copier tech.it is costly to fix.
Feb 05, 2008 | Sharp AL 1631 Copier
L4 error code
L4:The Main PWB sensed a Main Drive Motor MOT1 problem.
The main drive motor has a small white helix gear attached to the drive shaft.
Most likely that gear has cracked and is slipping on the shaft.
The main drive motor itself may be bad, either way, the motor will most likely need to be replaced.
Jan 14, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
129 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
