Question about Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
Check call restrictions 34 cant make any calls
I cant make any calls
  • conangroup
    conangroup Apr 04, 2013
    THE EASY FIX!!! TAKE BACK PLATE OFF...PULL BATTERY 5 MINUTES...DONE...FIXED...
Just turn off the set, and turn it on again. It solved on my tracfone service. Good luck!
Posted on Jul 31, 2009
  • wllmwhitmire
    wllmwhitmire Nov 18, 2013
    THANKS MUCH....Did the Trick................
It means you have no signal.
Posted on Jul 28, 2009
5 Suggested Answers
SOURCE: I have a motorola trac
JUST DELETE ALL OR SOME OF YOUR DIALED CALLS
Posted on Jan 21, 2009
SOURCE: Call restriction
I have the same problem with my Motorola tracfone. After fooling with it for about one hour, I discovered that for some strange reason, if you turn the phone off. When you turn it back on, you have to wait about 8-10 minutes and then all calls go through with no -34 restriction.
Gary
Posted on Feb 25, 2009
SOURCE: i try to dial but it says check call restrictions -34
I'm having the same problem too. Except this is a new phone, I just placed the battery in it yesterday and charged it for 5hrs as stated. I followed the instructions and nothing is happening either. I get the same error. I ialed the number with the 1-618 and the 618 and even witout the area code.. I'm puzzled. I have no landline/home phone this is my very first cell phone and can't call safelink.com ugh frustrating.
Posted on Dec 28, 2009
SOURCE: on a Tracfone, what does
it means that you have moved areas of where you initally activated the phone in (city, state) and your new area support a better technology or better carrer.
main carriers t.f. use are vzw, at&t, t-mobile. most of the time GSM phones will display call restriction so u could get a cdma phone instead.
there is like 20% chance to fix it but all in all, u'll get either a new SIM card or phone of different technology.
any tracfone questios, email starfire2k4@yahoo.com
Posted on Mar 07, 2010
Can't use phone, call out, get call restriction 34 message
see the link. Contact your telco.
Long after the fact, but in case someone searches for "call restrictions -34" info, as I did....
I called Tracfone Exec Resolutions Staff at 1-800-876-5753 and was helped very professionally by an agent. We found that the phone still identified with the first SIM card that I had installed, rather than the replacement I had installed in order to be in AT&T/Cingular network rather than T-Mobile. Within 15 minutes, he had walked me through entering one string of codes and a few parameter checks, turning on/off phone twice...I was then ready to go with a fully functioning Tracfone.
So, this issue can be resolved. Not sure if others problems will also be related to the SIM card issue, but it is a possibility. Hope this helps someone.
tracfone call restriction 34 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
Aug 9, 2009 - Why do I get tracfone call restriction message 34? ...tracfone call restriction message 34? I have a Motorola Tracphone with sufficient minutes, service days and charge bars. I have received call restriction 34 messages infrequently, but they have ... Question about TracFone® V170 Cellular Phone. 1 Answer ... Can't use phone, call out, get call restriction 34 message
12 Mar 2018
SOLVED: Tracfone call restriction 34
8 Sep 2014
tracfone restriction 56 Questions & Answers (with ...
13 Mar 2011
Why does my safelink phone say check call ...
4 Aug 2010
More results from www.fixya.com
Check Call Restrictions -34 (?!) - HowardForums
https://www.howardforums.com/showthread.../1529955-Check-Call-Restrictions-34-(-... May 23, 2009 - 13 posts - ‎12 authors
I got this message today - "Check Call Restrictions -34" - on a recently activated T101g which has only ever had 1 SIM (ATT). It also showed an icon for "out of your service area". I turned off the phone and waited 15 minutes. When I turned it back on, it had a signal & worked fine. I turned it off and back on a ...
What does the message--check call restrictions -34 mean and how do ...
https://www.justanswer.com > ... > Cell Phone Technician > Tracfone Problems May 25, 2011 - Hi, thanks for using. Technician's Assistant: that message appears if you have blocked any specific number of your contact list. It is not a Cell Phone problem, it's just the telephone Company is restricting the calls to your phone. You will have to contact your telephone company to check the Call restriction ... https://www.howardforums.com/showthread.php/1529955-Check-Call-Restrictions-34-(-!)
Mar 12, 2018 | Cell Phones
What is call restrictions-34
I believe that is international calling.
May 31, 2016 | Tracfone Wireless LG 440G
I try to call my safe link phone says check call restrictions 34,how to I fix this!
Did you make at least one call per month on the tracfone? If not this maybe one of the reasons the call is restricted. You may have to manually receive your minutes for the month by: Pressing the menu key, when the prepaid menu appears press select. Go to redeem airtime or add airtime. If your screen displays a message scroll down and press ok until you see Card# or Airtime Pin. Enter 555 then press enter. If it says promotional code select no. Make sure you keep your safe link phone on to receive your minutes and see if that fix the problem. If that doesn't work you may have to call safe link at 1-800-378-1684.
Best Regards!
Feb 25, 2015 | Samsung Tracfone Sgh T105g Cell Phone...
Restriction 34
plug into computer and refresh software, check sim card, for corruption . replace it.
Jan 11, 2015 | LG Cell Phones
It relates to a problem with cell phone the cell phone towers. To resolve the problem you just need to disconnect and reconnect to the tower. The easiest way to do this is to:
1) shut the phone off
2) wait a few seconds
3) turn it back on again.
If this does not resolve it just call tracphone support and they can assist you further.
Sep 08, 2014 | Samsung Cell Phones
My LG800G net10 cell phone says check call restrictions-34 but yet it still has minutes and I cant call or text or even get online.. why? What to I do to fix this?
go to call log then go to its settings or options. then see if you can turn off the call limit. or maybe turn off the fixdial.
Aug 18, 2014 | Cell Phones
The Samsung tracefone won't let me call out it's
Call restrictions are due to SIM card problems (Maybe you are using the wrong network, or your SIM card is not being detected by your phone) Another possibility is that your cellphone is restricted by the service provider. Why don't you give them a call?
Oct 25, 2012 | Cell Phones
Call restriction
ALL YOU HAVE TO DO IS DELETE SOME OR ALL OF YOUR DIALED CALLS.
Dec 29, 2008 | Motorola Mobility TracFone® V170 Cellular...
Call restrictions -34 everytime i try to make call with my cell
Restrictions -34 Is No signal Went outside my house works fine.Found that I had Poor signal in my house
Dec 02, 2008 | Lands Phones
Motorola Mobility TracFone w175 PayAsYouGo Cell Phone Logo
7,090 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
