Question about Intex 1500 Gph Swimming Pool Filter Pump Above Ground
Need help downsizing pool pump connection
My Intex Pool Pump 1500 gph stopped working so I was trying to use my old 1000 gph pump but I am need to be able to convert my 1 1/2" pump hose that is connected to the pool to adjust down to fit a 1" fitting on the other pump. I went to two hardware stores and no one could help me. There has to be an adapter out there that would work.
  • 9 more comments
  • medavis24 May 29, 2009
    Yes, I want to keep using the original flex hose that came with the Intex 1500 gph Pump but attach it to a 100 gph Pump
    I meant to type a 1000 gph pool pump from my old pool.
    The old pump has the 1 1/2 in flex tube with a threaded ring attached that screwed on to the old pump and the new pump nipple is not threaded, it used a clamp.
    The pump I want to use is the standard 1" nipple without threads that you just slide on the flex tube and clamp it down with a metal clamp.
    Here is the hose that is connected to my pool, (1 1/2")but I need to be able to connect one end to my new pump which is just a non-threaded 1" nipple. Sorry, I am trying to explain it better. Thanks!
    No, I know nothing about mating pve piping/adapters with solvent? Is that the same as pipe glue?
    Yes!
  • medavis24 Jun 01, 2009
    Thanks charlie. Just wanted to let you know I got it fixed Friday after work. I went to Ace Hardware and found a rubber reducer 1 1/2" to 1" with clamps and attached them and everything works great now. If I have other problems, I will definitely contact this site.
  • Samuel Charles Spriggs May 11, 2010
    I'm not totally visualizing this yet, but if you had a 1 1/2" non-threaded nipple on the new pump, would that allow you to clamp the 1 1/2" flex hose onto that nipple?
    Yep, I was reading 1000 gph -- just because of the 1" ports, I guess.
    I have extensive experience with adapting all types & sizes of hoses & pipes to all types & sizes of hoses and pipes.
    I assume you have 1 1/2" nipples on the old pump and 1" on the new pump. And, the flex hose clamped onto the 1 1/2" nipples.
    One way to do this is to install a 1" to 1 1/2" adapter on the new pump so you have the same size nipple you had on the old pump.
    I'm assuming further, the nipples are CPVC. There are adapters available to do this job. The adapter(s) you use will depend on whether you have threaded or non-threaded nipples on the new pump -- could you tell me what you have on the new pump?
    And, also correct any of my assumptions above.
    thanks...
    Charlie
    Going by the picture, it appears that you are using flex hose -- is that correct?
    President:
  • 1,489 Answers
Okay. I think I gotcha covered.
I have one mocked up here right in front of me.
Still going on the PVC pipe assumption...
- Install a PVC 1 1/2 " - 1" reducer on the new pump nipple.
- Install a short piece (nipple) of 1 1/2" PVC pipe in the reducer installed on the pump
- Install an 1 1/2" MIP adapter (PVC) on the 1 1/2 " nipple
- Screw the hose onto the threaded 1 1/2" MIP adapter.
There are several ways to do this -- the above is a good way.
Have you ever mated PVC piping/adapters with solvent? I can help you with the details of this if your unfamiliar with it...
Charlie
Posted on May 29, 2009
  • Samuel Charles Spriggs May 29, 2009
    I've never heard it called pipe glue, but I guess the term fits.
    The process is pretty simple. Do you want to give this hookup a try?
    Once you get the parts, drop me a line.
    Do you know pretty much what to get?
    Charlie
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Just replaced my 1000 GPM Intex filter/pump with the 1500 GPM. Worked great for about two weeks. Now it doesn't pump much with the filter in. Seems to pump fine without the filter.
The filter needs to be cleaned. the cartridge should be removed from the housing and sprayed on the o with a hose and sprayer. A strong, concentrated jet of water works best. I hope this helps.
Aug 15, 2011 | Intex 1500 Gph Swimming Pool Filter Pump...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Intex pump 635 is a P.O.S.! How do I hook up a different pump?
I just left the standard intex connection on the pool and I cut the standard connection off of the filter side and I slid the hose over the top of a 1 1/2 pipe and put 2 stainless steel hose clamps over them and it worked fine
Jul 23, 2009 | Intex Krystal Clear Model 635 Pool Filter...
How do you install the adaptors part number 10722
You cannot use them unless you have a 1 1/2" female adapter for those to screw into.
Jul 09, 2009 | Intex Pool & Spa
I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Jun 28, 2009 | Intex 4000 GPH Filter Pump
Intex 1500 Gph Swimming Pool Filter Pump Above Ground Logo
250 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
