Question about LG 24 in. LDF7810 Built-in Dishwasher
We have been told it is the motor which is locked, and it stop working, is there a way to fix it without going to an appliance store, can i fix it myself and what would i need to do
The dish waher turns on after a few minutes it starts to beep and The letter LE starts to blick,
  • 6,784 Answers
The diagnosis is correct. the windings in the electric motor are separated and damaged. replace this motor asap if possible.
Posted on May 29, 2009
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
How to fix serpentine belt on chrysler 300 with a seized air compresser
Try by going to an auto parts store. advanced auto, autozone, ETC. tell them you need a belt for your car without a/c. Most of the time you can get one! This will bypass the a/c motor. God-Bless!
Oct 12, 2016 | 2005 Chrysler 300
HELLLPPPP !!!! Audi A4 2003 Wipers don't work because an electrical fault !!! Hello everybody !!!! I have a problem with my wife's car: audi a4 (b6) 2003 1.9 tdi 130 hp, RHD Last week after a...
-You mean There is 12 V at motor terminal when you turn on the switch.
-Okay now disconnect power at motor and hook up voltmeter to motor terminal in Ohm. Any reading...?
-No. motor is bad.
-Yes. The motor is Okay.
-Next check ground terminal from motor to any metal part of the car in Ohm. Any reading?
-No. >>Need to redone ground from motor.
Mai
Aug 09, 2013 | Audi A4 Cars & Trucks
Replacement Motor for a Miele S143 Vacuum Cleaner
Your vacuum should still be under warranty. If they dealer does not fix it for free call Miele directly.
Jun 05, 2010 | Miele S143 Bagged Upright Vacuum
I have a Waring food processor model FP51071 motor will not go on
since I did not get a response from fix it and could not find a local repair store from fix it I called Waring the manufacturer and was told the motor will not work as a safety precauition until the top is locked in once I did that it worked fine.
If you had responded to me in anyway except to sign up and pay for your service I would have signed up now I am just annoyed .
Nov 11, 2009 | Waring Food Processors
My Mabe fridge stopped working. The fan in the
Your fix will likely involve replacing the fan motor. Until this is done, the freezer side will probably be okay; but very little cold air will be transferred over to the refrigerator side. The temperature in the refrigerator will likely get much too high.
Hopefully, there is an access panel where you can get to the fan. If so, it is not difficult to replace. The motor should be readily available at the appliance parts stores that do internet sales.
Oct 11, 2009 | Frigidaire FRS23KF7AB Side by Side...
2000 Volvo S80 door motor
this is a complete assembly and you will need to remove the door panel and replace it/price it first
Aug 25, 2008 | 2000 Volvo S80
Juicer does not work.
Had same problem...juicer stop working without any warning. First I took the unit apart and remove the on-off switch and capacitor and had them tested by appliance shop. Both checked good. Next I remove the small circuit board behind the face plate below the motor shaft; circuit board was coated with oil and shaft grease. Appliance shop did not know how to test it, so I clean it all up and reassemble the unit. I told God is it worked I would praise Him. Hallelujah to God ... it worked. I hope my experience helps someone. God is good.
Jul 18, 2008 | Champion 2000+ Household Juice Extractor
Washer wont agitate with med - large loads
Without knowing the age of your machine, your agitator "dogs" may be wearing or worn out. It should be fairly easy to check them out. You will need to figure out how to remove the agitator Usually the agitator will have a fabric softener dispenser or a cap on the top. Pull the dispenser/cap off the top of the agitator and you may see a screw holding the agitator in place. Once you lift the agitator out, the "dogs" should be visible. Most appliance stores should carry the dogs for your particular washing machine. I've added a couple of photos so you have an idea what to look for.
Black powder under the motor??? The motor uses carbon "brushes" to electrically make the motor move. Without going into motor theory, I would tell you that the black powder, in a small amount, is normal. The brushes can be replaced, and again, can be found at most major appliance dealers
Jan 11, 2008 | Amana ALW880WH Top Load Washer
Won't spin
you need part number 12002039. its a motor/ motorcontrol kit. there have been alot of problems with this motor so maytag redisigened it
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Dishwashers Logo
177 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
