Question about Brother MFC-8860DN All-In-One Laser Printer
I have a BROTHER MFC- 8860DN that makes black streaks on copies
All copies come out with dark black streaks. I changed the toner and cleaned the drum with a soft cloth. It was better for a few hours then started doing it again.
    Scholar:
  • 34 Answers
If this is only happening with copies and not straight prints, it is possible that the problem is with the scanning unit. Use the soft cloth to clean the scanner area to the left side of the machine where pages are scanned when run through the page feeder. A spec of dust or other debris in this area will appear as a streak along the length of the page.
If it occurs on all prints, You may need to replace the drum or clean the fuser unit.
Posted on May 29, 2009
How to Reset the page drum count on Brother MFC-8860DN
Open door
remove drum and toner unit
remove toner from drum push on blue tab on side to release
reinsert new toner in drum
reinsert unit in machine
leave door open
hit clear/back on panel --- says new drum-- hit yes
says accepted
close door
Dec 11, 2012 | Brother MFC-8860DN Printer
Drum cleaning function doesn't remove toner spots
Did you check:
1) are there wisible marks on drum - like spots, streaks,... if no, first check the copie glass if it appears when you make copies.
2) does it appears when you print too? If yes, also check the fixing unit for spots, ... , but if there is also on drum, that means that the cleaning blade is deformed on some places ( the place where the toner streaks are ). You can use some paper A4, fold it on half and ran it beetwean the drum and cleaning blade.
But if the blade is too heavily worn out, the best solution would be to replace drum unit.
Hope that I helped even a little bit.
Jun 14, 2010 | Brother MFC-9840CDW Laser Printer
Brother MFC 8660DN "Toner Error Reinstall Drum I got a new drum, new toner and still printer isn't working and show the error reinstall drum unit please help
Pull the drum/toner out and look into the machine, at the wall on your left. There's a little plastic lever there that pivots to detect a new toner cartridge. Sometimes the lever gets sticky; wiggle it to free it up. If you feel brave enough to remove the outside cover of the machine on that side, you can put a dab of grease on the lever's pivot.
Apr 04, 2010 | Brother MFC-8860DN Printer
Brother mvc8860dn runs much slower now
your fusing thermistor is getting wrong temperature mesures ,exchenge the fusing section or at least clean the thermistor.
Jan 08, 2010 | Brother MFC-8860DN Printer
BROTHER MFC-8860DN EVERY TIME I PRINT TWO DARK LINES PRINT ON EACH SIDE OF THE PAPER?
I had a similar problem but it was only one dark line on the right side of each page. I just changed the drum while keeping the same toner and the problem is gone.
Dec 11, 2009 | Brother MFC-8860DN All-In-One Laser...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Print problems with brother MFC-8860DN
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother MFC-8860DN All-In-One Laser Printer Logo
1,178 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
