Question about Kenmore 16719 Dishwasher
Dishwaher wont drain-checked drain hose and its clean
Checked drain hose-clean dishwasher wont drain
  • 234 Answers
The problem is most likely the drain valve. It is electrically operated and with your problem it is the most common cause.
If you need more help, post a comment.
Thanks,
Tim
Posted on May 29, 2009
Dishwaher not draining
apart from cleaning the filters at the bottom, have you checked if the kitchen drain is not clogged. Also if you have a garbage disposal unit in the kitchen sink, make sure it has been run before you turn on the dishwasher. Will be helpful if you can describe the problem with details of the dishwasher and also which wash cycles have you tried and list any alarms lights on the panel of dishwasher.
May 23, 2012 | Maytag Dishwasher
DISHWAHER WONT COMPLETELY DRAIN ALL THE WATER OUT AFTER WASH CYCLE. JUST CHANGED OUT SINK FROM DOUBLE TO SINGLE.
drain hose is to low to sink connection zip tie side connected to sink up towards bottom of cabinet top so water dosent backflush into dishwasher from sink draining
Jan 27, 2011 | Maytag EPIC MFW9700S Front Load Washer
There is a lot of standing water on the bottom of the washer and it just wont go down. Tried using DRANO but it didn't work at all.
if you have had a new garbage disposal in stalled then make sure the plug has been taken out of it.
If you have a wet dry shop vac you can use it to drain the water from th unit by attaching it to the end of the drain hose. if the water comes out easy you may have a faulty pump if it comes out kid slow then there is a restriction some where in the line of the sump area of the dishwaher and needs to be cleaned out.
Nov 24, 2010 | Dishwashers
Miele g 842sc plus dishwaher
hi,
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele dishwaher won't drain, water in the bottom of filter. I have cleaned filter, water still won't clear.
hi,
Hope this helps.
Jan 25, 2010 | Dishwashers
How can i clean out the drainage hose on n lg dishwaher model lds 5811BB
First of all, disconnect the electrica plug under the sink. Then you can remove the kickplate cover on the washer and you can access the hose to remove it.
It most likely goes to an "air gap" on the sink. That's the noisy vent is typically located to one side of your faucet. alot of times, that's where the drain hose will get blocked. Take the large hose loose from this first to check for blockage and build up...
Many times the blockage can't make it thru the air gap...
So if you clean that , you're probably have got it all.
K
Jul 30, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
The dishwaher dose not empty even with the pump running
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Mar 01, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Where is the drain screen at in my My frigidaire dishwasher
generic reply normly in the center and looks like a plastic grating, but is your drain hose kinked?
Oct 25, 2008 | Frigidaire Dishwashers
Dishwashers
you have a draining problem ... check the garbage disposal that it is clear.. then check your drain hose and the the drain trap inside your dishwaher....
if all this don't help then go to the drain pump ... hope it helps
Jun 14, 2008 | Dishwashers
Kenmore 16719 Dishwasher Logo
543 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
