Question about Maytag MAH6700AWW Neptune Front-Load Washer
Water between the drum even when not on
We have a Maytag Neptune washer that really smells like mildew. I am about to try some "Smelly Washer" product to see if that helps, but I noticed that if I put my hand inside the washer when it's off and spin the drum, I can hear a lot of water spinning around. I wonder if this is normal? If it's not, I am thinking that could be the root of the mildew smell - perhaps there is a blockage in the drainage system. Does anyone have any insight? Is this something I can fix myself or do I need to call a repair man? (I have a stackable dryer on top so it would be difficult to pull the machine out from the wall on my own.) Thanks!
    Problem Solver:
  • 8 Answers
Water between the drum is a common problem with not only front load but top load as well.
Front load washers such as the neptune have an airtight/water tight door which will hold moisture in the machine when closed. Try opening door and keep open between loads. In addition, a monthly cleaner specific for the front load machine will help this problem
Posted on May 30, 2009
Why would my washer suddenly quit while draining between rinse and spin?
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details, sorry.
Jun 05, 2017 | Maytag MAH6700AWW Neptune Front-Load...
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
First Choice Appliance
Aug 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Jul 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water isn't completely draining
the water sound is normal ,to make the machine balance there is a liquid in the shell of the tub that is always there.As for the smell start leaving the door partially open and mold/mildew cant form.
May 30, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Apr 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mildew smell and sound of water
Momma, Maytag put out a service bullitin on this problem. TB26-72. This is a common problem on your model. Why don't you google the service bullitin and it will give you the instructions they have for this problem. If you can't find it, post back and I will post them for you...Catriver...post back.
Sep 22, 2006 | Maytag Neptune MAH55FL Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
205 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
