Question about Cobra 25 LTD 40-Channels Base CB Radio
Af audio power amp
I am working on a Cobra 25 LTD Classic radio. Is there a replacement part through NTE or others for the YD 1022? The audio output chip is running too warm.
  • 585 Answers
Just because the chip is warm doesn't mean it's bad, especially if it seems to work fine otherwise. Do however make sure that the device is properly heatsinked, and inspect the work done in the process of any modifications. If for some reason the device is self-oscillating it could do so at a frequency above hearing thereby going unnoticed. That will cause the device to overheat, and also make modulation weak and the RF to splatter out of band. You'll have lots of power on the RF wattmeter, but people can barely hear you if that's the case.
Posted on Jul 11, 2009
How do i adjust dead key on a cobra 25 ltd classic cb
The only "adjustment" is the AM POWER trimmer. Lowering this will lower your dead key but will also lower your "swing" power. the TX circuit must be modified to lower the dead key and maintain full output. there are many articles on the web for such modification.
Apr 12, 2013 | Cobra 25 LTD 40-Channels Base CB Radio
I just purchased a cobra 29 LTD Classic mobile CB radio.Pro tuned high performance Mosfet Final I have a palomar 450 LD mosfet linear.will i have any problems?
Not if the power output from radio to amp is set correct and the jumper for coax is correct length and there is absolute perfect match between them and the antenna used. Afterthought: also the amp better be connected to something big enough to power it.
Apr 29, 2012 | Cobra 29 LTD CB Radio
I have a cobra 25 ltd classic with a 102" whip. It
hello firstly it would be wise to connect your power lead directly to your battery secondly have you checked the vswr on the antenna make sure it is tuned to your radio i presume you have an swr metre and lastly check all coax connection make sure none are shortening out check pl259 at rear of radio and also check lead goin into antenna you can ajust the antenna by raising or lowering the whip .when you acheive 1.5 or better tighten up it should work ok for then
goodluck
Jan 09, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
What Voltage Does The cobra 25 ltd classic use?
12 volts, around 15 amps. For a base station, try an Antron-99 groundplane antenna.
Jul 19, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 ltd wx wont power up
You most likely blew a Diode that is back near the power plug.
It is easy to fix the diode but if you continued to apply power you may have damaged other parts including the audio chip.
Dec 22, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 07, 2008 | Cobra 29 LTD CB Radio
Af audio power amp
No!
On the YD1022 the pinout is: Corresponding pins on the TA7222 :
1,5 & 6 are ground 3, 7 & 8
2 is audio input 4
3 is feedback 6
4 grounds through a capacitor for frequency compensation 5
7 & 8 are audio output 9
9 & 10 are +12VDC VCC 1
The TA7222 also uses pin 10 for feedback & freq. comp. The circuits are very different & would need to be redesigned to interchange these chips.
Jul 16, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Fuse
There are only a couple of components that could cause the fuse to blow. They are:
1. Reverse protection diode (D23)
2. filter capacitor (C123)
3. Outputs (TR14 & 15)
4. Audio Amp (IC4)
5. Zener Diodes (D22 & 19)
6. the fuse itself (it should be 2 Amps
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FIXYA.
Feb 12, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Sound, But VERY VERY quiet
I have the identical model and also had the same problem. I took it in to an appliance repair and they found a problem with the output circut something about a burnt transistor is what they said. I had them replace it and has been working fine since. Hope this helps.
Feb 07, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
245 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
