Question about RIM BlackBerry Bold 9000 Smartphone
Memory Cleaning
If I enable the "Memory Cleaning" where it says Registered Cleaners and activate "Clean Now" will it eliminate something important.
  • edgarpaulk May 29, 2009
    That was fast!!! Thanks and I will proceed to do the cleaning as you stated "feel safe".
    President:
  • 2,004 Answers
No. feel safe.
Posted on May 29, 2009
  • Onifade Adewunmi
    Onifade Adewunmi May 29, 2009
    Dont forget to rate my solution fixya cos it solves your doubt. Murphybanton
How to clean oven model JSP46D P1BB
That model is self cleaning . So you have to remove the oven racks and press the button marked self clean. The self cleaning cycle will last anywhere from 2-4 hours . once the oven unlocks after the cycle is over you have to wipe the surface with a clean clothe. It is very important to never use regular oven cleaners (i.e. Easy Off ) in a self cleaning model. If you need to spot clean something without using the Self cleaning mode you can make a paste of baking soda and water and let it sit for an hour before wiping.
As far as the top is concern, use a mild soap and a dish cloth on an everyday basis. There is products specifically designed to clean the ceran tops (good brands are "Cerama Bryte" and "CookTop", they are available at any Wal Mart) you should use one of those cream cleaner at least once a week. If something is really baked on , you can use a razor blade ( same ones ones used to removed paint off windows) or a scotch brite pad ( the blue one only.. the yellow one is too abrasive)
Mar 14, 2011 | GE Ovens
What to use to clean flat screen monitor
As an easier option you can use dust cleaners like Colin etc but if you want something specific go to a nice Computer shop ans ask for LCD cleaners and use that. These LCD cleaners have high percentage of Phenol in them and less percentage of alcohol. And Phenol is considered best for cleaning LCD but you should not use something that contains only Phenol as its very reactive.
We don't use something that contains high % of alcohol as it is highly inflammable.
Thanks !!
Please rate the solution if you like it.
Nov 23, 2010 | Computers & Internet
How would you clean an oven if you didn't have hot water or electricity? We clean out foreclosures that usually do not have water or power available, I need something that will clean the oven and the...
There are several products that you can use, you can get spray on cleaners, or ones that you paint the interior with, after letting stand for a while, you rinse and wash the interior with cold water.
Check on line for OVEN CLEANERS OR CLEANING PRODUCTS.
Please rate my solution.
Thanks.
Oct 19, 2009 | KitchenAid Ovens
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
Cleaning washing machine
THERE ARE COMMERCIAL WASHING MACHINE CLEANERS ON THE MARKET. YOU CAN ALSO USE AUTOMATIC DISHWASHER DETERGENT IN A HOT WASH TO CUT GREASY BUILDUP IN THE WASHER. BE SURE TO GET THE WATER A LEAST 120 DEGREES TO ACTIVATE THE DETERGENT. YOU CAN ALSO USE A BLEACH BATH TO CLEAN THE WASHER, BUT DON'T COMBINE THE BLEACH WITH ANY OTHER CLEANERS. IT CAN BE TOXIC.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
Cleaning
unable to clean see troubleshooting and routine maintenance. unable to use it from then
unable to clean
Feb 19, 2008 | Brother MFC 420CN All-In-One InkJet...
Deep hard core cleaning
From GEAppliances.com: Microwave - Cleaning Recommendations To minimize the possibility of electric shock, unplug the microwave from the power supply before attempting any maintenance or cleaning. Spills and spatters clean up easily with a damp, soapy paper towel or sponge. It is best to clean soil as soon as it appears. Baking soda and water may also be used. If the food has cooked onto the interior, heat one cup of water on full power for three minutes. The heat and steam help to soften the food. After the three minutes, allow five additional minutes stand time then clean as usual. A non-abrasive scrubbing pad cleaner works well for stubborn stains. You may use mild dish washing liquid or cleaners specifically listed for cleaning interiors of microwave ovens such as MicroBryte® (wx10x3030) or Microwave Oven Magic®. We do not recommend using other detergent based cleaners because they can cause the plastic parts to crack. You may purchase microwave interior cleaner by calling our parts department at 1-800-626-2002, on-line from GE Parts or from your local grocer. For stainless steel interiors of microwave/convection models, we recommend a plastic, soap-filled scouring pad. Rubbing gently with this pad will help remove soil. For the door surfaces (both interior and exterior) We recommend you use only mild, non-abrasive soaps, or detergents applied with a sponge, or soft cloth. For the control panel Wipe with a soft, damp cloth. Dry immediately with a soft cloth. Do not spray any solution directly onto the controls Important: Commercial Oven Cleaners, abrasive cleaners, or cleaners containing ammonia or bleach (can make the plastic brittle) should not be used on any part of the microwave. -- From me - Maybe local restaurants in your area would have some tips? Otherwise, try a Google search for keywords: cleaning stainless steel oven
Aug 05, 2007 | GE Advantium 120 Convection/Microwave Oven
RIM BlackBerry Bold 9000 Smartphone Logo
59 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
