Question about Kodak EasyShare Z612 Digital Camera
The lens will not extend
When I switch on my Z612 digial camera, the lens seems stuck and won't extend. Instead the camera switches itself off immediately. Can you help?
  • 744 Answers
Hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Posted on May 29, 2009
Vivitar 35-200 macro FD mount lens for Canon doesn't extend to telephoto. It seems to be stuck at 35mm. Any tips? Disassemble, special buttons, tricks?
Did you try putting the camera and lens in Manual Mode and focusing by hand? On Many cameras there is a tiny switch on the lens that limits your focus ability to either FULL or LIMIT.
Nov 13, 2013 | Vivitar Cameras
Digimaster Happycam 5010 Problem: The shutter that protects the lens is stuck fully open. The camera is stuck with lens fully extended. ERROR 2 appears on the screen. The LED near the top left of the...
That is probably a lens error, or a problem with the main pcb inside the camera.
Only easy fix is checking if the problem disappears by removing batteries and putting them back.
Oct 12, 2008 | Cameras
I have a weird problem. When i put the 50mm 1.8 on my D90 it continues to autofocus even when I switch the camera body to M mode instead of AF with the switch. I would like to be able to manually focus...
You probably have a problem with the A/M switch on the body-- flipping that switch should extend or contract the autofocus pin that drives the lens. This particular lens doesn't have its own focus motor, so there's no way that it could be focusing on its own without the pin from the body driving it.
Try taking the lens off of the camera and looking at the autofocus pin as you flip the switch from auto to manual focus.
Mar 10, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
Camera shut down with lens extended. It will no longer turn on. Tried new batteries. Did not work. Small green light next to settings wheel blinks when trying to power on. Any Ideas?
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Jul 27, 2010 | Kodak EasyShare Z612 Digital Camera
My lens for my ixus 750 is stuck open. when
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
When turning on the camera it shows 'Lens error restart camera'
Aug 10, 2009 | Canon PowerShot A470 Digital Camera
I have dropped my camera and now the lens is stuck in the out position. When I switch the camera on, I get the Cybershot logo on the screen with the start up sound and then it powers down with the lens...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 05, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 07, 2007 | Canon PowerShot G5 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
158 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
