Question about Samsung HLN467W 46" Rear Projection HDTV
I have a Samsung HLR 4677W.... color goes to green & purple
After approximately 2 hours of operation the picture begins to flicker and then the color changes to green and purple. Once the set is turned off for a short period of time and then turned back on the color is normal.... for another 2 hours and then goes to the green and purple.....
The color wheel has been replaced and is not the problem.
Any ideas as to what is the cause???
  • 111 Answers
SOURCE: picture loses color on samsung HLN4365W
if the picture is still visible but lacking color, it is not the lamp. check the color wheel and make sure it is working. replacing the color wheel is a pretty easy task and can be performed by yourself without many problems. as a sidenote, older samsung dlp tvs seem to experience this problem quite often, although they usually sound like someone strangling a cat before the bearings go out.. should carry your replacement for 100 USD or so, the part number is BP96-00250A.
before replacing it, make sure your old one isn't just stuck or not spinning at full rpm, if this is the case, you can usually remove it and clean the motor using electronic or contact cleaner that is safe for plastics.
to check everything out, you will need to remove the back panel of your tv, then power it up (keep kids, small animals, hands and such away from the back while powered up), take a look in front of the projection lamp and see if the wheel is turning. if not, a very good writeup is available here, this is the writeup i send my own customers to if they feel like attempting the repair themselves.
replacing the color wheel is actually not very hard at all, if you have ever worked on your own desktop pc (installed a new drive or upgraded it yourself) then you should be able to do this with limited difficulty.
hope this helps,
Posted on Nov 16, 2007
  • 1139 Answers
SOURCE: Samsung HLN5065W only displays black & white picture
Hello,This problem denotes a defective color wheel, I would not suggest that you attempt to change it becuse of the risk of causing more damage. I would advise that you have the Tv repaired by a qualified TV technician, due to problems I have seen when repairing sets like this due to improper reinstallation of the color wheel.I hope this helps,Thank you,Shuttle83
Posted on Jun 11, 2009
  • 1284 Answers
SOURCE: I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
Posted on Sep 10, 2009
  • 336 Answers
SOURCE: after changing color wheel on my samsung hlr 5067w
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works: Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Posted on Feb 09, 2010
  • 7 Answers
SOURCE: Samsung HLR5067 flashing green
If this doesn't fix your problem, it may be the lamp. I experienced the same sequence minus thunderstorm, but it got to where it went from green verticals to just cycling on and of 5-6 times. New lamp did the trick.
Posted on Dec 06, 2010
How do I repair the color on my Samsung LCD TV. I can still see the picture but 3/4 of the TV goes green/purple/pink and the bottom 1/4 has normal color.
The T con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
May 28, 2016 | Samsung Televison & Video
Is my color wheel need replaced?
the bearings of the color wheel could be worn. the screws hold it in place, & there is a plug-in wire connected to it.
for part# contact:
Dec 02, 2014 | Toshiba 50HM66 52" Television
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Hi, i'm having trouble with my HLN 5065w samsung. The color on the screen starts out normal, then flickers to neon purple and green. then the screen goes black completely and I have to unplug it. Do you...
Your Convergence has gone out and very likely needs work, this is the most common problem inthese big screens.
You may not be able to realign that picture without some new parts unfortunately.
There are some circuits that align the RED, GREEN, and, BLUE, picture tubes to make the picture you see.
The components that do that job are called "convergence" circuitry. The usual components to fail are the "Convergence Amplifiers" which are usual a pair of Integrated Circuits mounted to a large heat sink.
the repair cost is between 200 to 400 usd.
Post further comments if you need more help or information...
Good Luck!!
Oct 16, 2009 | Samsung HLN5065W 50" Rear Projection...
Screen has major digital ditortion (green lines, heavy contrast)
Personally i haven't had this problem but it seems to be that it's either the video board or the dmd board.. if you select the service menu and it looks like the rest of the screen, it's the videpo board, if not it's the dmd board
Jun 30, 2009 | Samsung HLR6178W 61" HDTV
Pixilated (purple) on top half of tv
Not your bulb, prob with the display unit. Could be a driver or decoder IC...accordianman
Sep 27, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Samsung HLN467W 46" Rear Projection HDTV Logo
93 people viewed this question
Jerry Greenberg
Jerry Greenberg
