The engine start and turn off when I select gear and at times the engine start and shutdown instantly
SOURCE: 2006 Beetle will not start every time ignition key
sounds like the park/neutral safety switch is having an issue. Sometimes you can get at them and clean them, but most likely you will need a new one.
SOURCE: 2007 lexus, vsc and engine check light on,
Hello, This problem results from the Temperature information not going to the ECM. In short, your car needs to know it needs the "Cold engine" cycle to kick in. This cycle sort of acts like a choke with respect to enriching fuel requirements, but also changes the timing for Cold start conditions.
What you are trying to do is start a cold engine with warmed up engine settings. This is why you are having your problems. Go to a good Autoparts store and ask what you need in the way of Temperature sensors for your dash and engine controls and then install the new parts.
