Question about Canon Office Equipment & Supplies
Rpc server error installing driver
Two days ago when I went to print an article, it shows I need to install a printer. Then I reinstalled my printer, it shows there was a problem installing Canon MF 4350d (UFRII LT) An error occurred during the installation of hte device. The RPC server is unavailable. What should I do now?
    Master:
  • Canon Master
  • 867 Answers
Hi. Have you try to install the printer in other pc ?. It seem to be a pc software error
Posted on Feb 11, 2018
5 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: RPC server is unavailable
Solution #1posted on Dec 23, 2007 by Silan
Try :- http://www.fixya.com/support/t311909- printer_installation_problem
1.open a Command Prompt window(click start--
-->run--->type cmd and press OK)
2.key sc config spooler depend= RPCSS (note
the space after depend=) and press Enter.
Try reinstalling the printer.
Or
1. Start / Run / MSConfig / OK.
2. Select the Services tab.
3. Make sure that each of the following
services is checked:
Plug and Play
Remote Procedure Call (RPC)
Remote Access Auto Connection Manager
Remote Access Connection Manager
4. Press Apply.
5. Press Close.
6. Press the Restart button.
Try reinstalling the printer software. If the
issue does not resolve Please get back me.
Thanks
Posted on Jan 26, 2008
ginko
  • 19396 Answers
SOURCE: I have your Lexmark
You must download and install the updated software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Posted on Nov 30, 2008
acdr
  • 1913 Answers
SOURCE: I need help for printer installation.
remove temp files from your computer.then try.
free psace from c: rot driver
Posted on Jan 03, 2009
CreativeTECH
  • 1719 Answers
SOURCE: i have installed hp laserjet
RPC service may not be available or started on the client machine.
To start/ enable it go to 'Run Command' and type 'services.msc' , locate REMOTE PROCEDURE CALL (RPC) and start the service.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Posted on Dec 07, 2010
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
I have installed hp laserjet 1000 on server 2003.I have shared this printer to my network.I am even able to print from client machines remotely.But one of my client machine shows 'The RPC server is...
GoodLuck!
CreativeTECH
Dec 07, 2010 | HP LaserJet 1020 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Microsoft Operating System protocol is to install first and then always have drivers and applications install on top of them. More often than not the drivers are outdated and rendered unusable by many of the operating system updates and then need to be updated themselves by the relevant vendor or have to be uninstalled and then reinstalled. Of recent times this has become more and more of an issue due to complexities in the registry and in the COM fabric of the operating system. The registry often gets clogged up with superfluous entries and needs cleaning out to improve performance just like the HD inside the PC needs defragmenting occasionally. Unfortunately when many of the updates from Microsoft and many other software vendors are applied they leave their old entries in the registry and just write new ones - simply because it is convenient and easier for them to do so.
Uninstall the application and drivers using the HP remove utility. It is not sufficient to use the Operating System uninstall as it does not work that well. The Registry, Application, Folders and drivers need to be totally removed.
A registry clean is recommended. You can do this by downloading a free 30 day use of Ashampoo from www.ashampoo.com and clean up your system of all the unnecessary entries. I have been using it for a few years now with grate success and no problems. You can always restore any deleted entries before binning them forever.
Once completed then reboot the PC then reinstall the HP drivers and application. Make sure these are the latest ones available from HP support for your operating system at
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3300221&lc=en&cc=au&dlc=en&lang=en&cc=au
Aug 09, 2008 | HP PSC 1210 All-In-One InkJet Printer
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at [email protected]
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
Canon MP810
Try this Click on start click on run type services.msc a box will open up with listings Check each of the following to see if they are running LexBce Server- should be set to Automactic Print Spooler- Should be set to Automactic Remote Procedure Call(RPC)- Set to Automactic If any of these items are different- change them by double clicking on the line. A box will open up make changes then click apply. Shut down and restart your computer. Hope this helps you
Sep 15, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Lexmark c524--have to keep reinstalling software
By software are you referring to the printer drivers? What error messages or behaivure are you observing?
Aug 01, 2007 | Lexmark C524 Laser Printer
"The RPC server is unavailable"
I?m assuming this is happening on a Windows machine. This is one of the really vague error messages that Microsoft give for an incredibly large number of problems. I typically see this on servers but have seen it occur on workstations. If you?re running XP, 2000 (server or Pro), or 2003: - Check and make sure your Remote Procedure Call Service is running. - There is an older vulnerability that tries to use a flaw in the RPC services. It is fixed if you copy of Windows is up to date so make sure it is. - Review your application log for any clues. If you need more assistance let us know your operating system, if it is fully patched and what is showing in your log file around the time you receive the error message.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
Open Questions:
46 people viewed this question
Clive
Clive
old marine
old marine
Ekse
