Question about Dell Dimension 4600 PC Desktop
Chipset heatsink not detected
My Dell Dimension 4600 says that the chipset heatsink is not detected, and is halting the system. I've done a bit of research and now know that this is a common problem in 4600s, which makes me a little ticked at Dell because their support team has been less than helpful any time I've had an issue in the past, meaning that this time around I'm going to attempt to solve it myself. I've seen that most people have reported that their problems arose from the chipset heatsink not being attached, or issues with the wiring. When I opened it up to take a look, both components are attached and appear to be in working condition - i.e. they are identical to the diagrams I've found online.
This has happened to me once before - my system was installed in a very dusty area, so there was a ton of dust buildup inside the PC. I vacuumed it out and the problem went away. This seems to be the issue once again, as I did find some dust attached to the chipset heatsink when I opened it up this morning, but even after vacuuming it out, the message still appears.
Any other options, guys? Your help would be greatly appreciated. :]
  • kseverance May 29, 2009
    Where can I find the BIOS overrides or updates? Is that available through the Dell product site, or is it from outside sites?
    Novelist:
  • 152 Answers
If the PC is still under warranty, request an RMA. If not, you won't get any / much help from them anyway.
Check to see if there is a bios override for system allert messages, also check to see if there is a bios update that pertains to this particular issue, sometimes they do fix thier own mistakes.
Other than that, you may be borked. Componant level repair is not usualy the do it yourself type of task.
If all else fails, you may need to get a new motherboard. This isn't so bad though, a name brand aftermarket motherboard such as an asus board will more than likely be more stable and functional than the lowest bidder bulk buys that dell sells. these componants are usually rejected from the original manufacturer because of faults such as this.
If you do go with a new motherboard, be sure to check, re-check, and then check again that all of your componants are compatable.
(intel sells slimmed down / less effective first and second runs in bulk to dell, and compaq)
Posted on May 29, 2009
Alert chipset heat sink not detected system halted dell xps 420
Sounds like your heatsink which is inside the computer and sits on top of the CPU is bad. There will probably be a fan that sits on top of the heatsink.
Look on ebay and purchase one for your system.
http://www.ebay.com
I found a new one below on ebay for $14.95 (the link is below)
http://www.ebay.com/itm/New-OEM-Dell-Dimension-9100-XPS-420-430-Heatsink-Assembly-XP850-/350520689627?pt=LH_DefaultDomain_0&hash=item519ca943db
May 12, 2012 | Dell XPS Computers & Internet
Alert! Chipset Heatsink not detected. System halted! is the alert that comes up when I turn my computer. What can I do?
Hi scotteg71121...
The alert is caused by a loose chipset heat sink.
Dell has a self test that prevents further damage by halting the system and displaying the message Alert! Chipset heat sink not detected. System Halted.
The solder joint seems to fail from constant tension and heat.
If you find the missing clip inside the computer you can solder it back in place and reattach the chipset heat sink wire hook.
If you can't find the clip you can replace it by bending a thin piece of wire in a half circle.
You can see a picture of where the clip goes on your computer motherboard by following the link below.
Please take time to rate me
http://www.aplusperfect.com/articles/chipset-heatsink-not-detected
Sep 05, 2011 | Dell Dimension 4600C PC Desktop
I'm getting this error message "chipset heatsink not detected system halted" What does that mean, and is there a fix for it?
it means that the chipset heatsink on the motherboard has come loose. There is a sensing circuit that is closed by the spring clip that holds the heat sink in place. One of the loops on it has broken, causing the error.
Resolution is motherboard replacement
http://shop.ebay.com/i.html?_from=R40&_trksid=m570.l1313&_nkw=dimension+4600c+motherboard&_sacat=See-All-Categories
installation information:
http://support.dell.com/support/edocs/systems/dim4600c/sm/parts.htm#1102134
Aug 08, 2011 | Dell Dimension 4600C PC Desktop
Hello, I've got a Dell Optiplex GX280 series desktop pc which has refused to boot up. Instead it shows an error saying "Alert! chipset heat sink not detected system halted! Would appreciate your...
Both your CPU and chipset have heatsinks to dissipate the heat they generate.
Over times, the heatsink compound between these components and the heatsinks
may dry up and no longer conducts heat efficiently. Your system on power up,
detects excessive heat from the chipset and if allowed to continue on, will burn
itself up. To protect it, your system shuts itself down.
Open up your case and inspect the chipset. Make sure the fan (if any) is running.
If it is, you may have to remove the heatsink (normally clipped on to the chipset)
and remove the old compound and apply a fresh new layer of heatsink grease.
While you are at it, also replace the heatsink compound of your CPU.
Jul 11, 2011 | Dell Optiplex GX280 (99301) Motherboard
Hello. I have an old Dell Dimension 4600C and I received an error: Heatsink Alert! Chipset heatsink not detected. System Halted. I've viewed various posts on line that this is a common problem. I've...
Yes, you need to re solder the missing wire loop loop to the motherboard. If you can't find the loop you form one by bending a thin piece of wire in a half circle. You will have to remove the motherboard to solder the clip back on.
Feb 15, 2011 | Dell Dimension 4600C PC Desktop
On boot up on my Dimension 3100C I receive the following error message: Drive 1 not found:Parallel ATA, PATA-0 (PRI IDE Master) Alert! chipset heat sink not detected System halted!
first off your going to ewant to hit f2 or f12 to get into setup and you are going to want to change boot oder to your hard drive. i then would open the comoputer up by taking the side of the case off and checking your cpu. u are going to wanna make sure there is a heatsink or fan securly on your cpu. if not this could over heat and burn your cpu up. heat sinks look like thisbadboy616.png
Jan 07, 2011 | Dell Dimension 3100 PC Desktop
I have a dell dimension 4600i. I want to upgrade
It should.. Here is a link to documentation.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/specs.htm
Apr 28, 2010 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 what kind of motherboard do i have.
Your Dell Dimension 4600 comes with an Intel motherboard with the Intel 865PE or 865G chipset running an Intel P4 class processor.
Here are the specifications for your machine and motherboard:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
Mar 07, 2010 | Dell Dimension 4600 PC Desktop
Alert chipset heat sink not detected system halted error message
It is NOT the CPU fan! There is a heatsink over the northbridge chipset adjacent to the CPU. The clip that supplies pressure to maintain contact between the northbridge and the heatsink has detached on one or both ends. There are wire loops at each end of the clip which feed into the motherboard. When the clip detaches (solder failure), it pops the loop out of the motherboard. The BIOS recognizes this condition as a heatsink failure, hence the error message.
Jul 10, 2009 | Dell Dimension 4600C PC Desktop
Dell Dimension 4600 PC Desktop Logo
354 people viewed this question
Alun Cox
