My Whirlpool Calypso top loading machine is making a whining noise and it runs o.k. until at 26 minutes left on the timer than it says ob (for off balance), I rearrange the clothes and start again, it goes back up to 27 minutes and then when it get back down to 26 minutes it stops again and says "ob". It will not pass the 26 minutes left. A different problem that I have been having with it, is that when it's done washing I open the lid and all this water, mixed with soap, falls down from the lid on to my clean clothes. I would appreciate any help anyone can give. spin and stop and won't drain up the water and have noise when spinning
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
