FixYa.com
Tags:
EdgeStar 12,000 BTU Portable Air Conditioner & Heater
Cooling on and off (by 3 users)
posted by uechan on Oct 22, 2007
hi, i have a 450z model. it worked fine for a couple weeks but now it has a strange problem.
i set the desired room temperature of 66 degrees F and the machine set on cool.
however, the machine only pumps out cool air for a minute or so. then for another minute, it stops and only has the fan working. afterwards, it'll turn the cool air back on but again, only for a minute before turning on only the fan.
what is the problem and how can i solve it?
i've already cleaned the air filters and adjusted the hose, frankly i'm out of ideas.
Comment by uechan, posted on Oct 23, 2007
wow, thats basically what the company told me to do:
Hello,    That rapid temperature drop as soon as the compressor turns on sounds like your temperature sensor may be loose. It is a thick black plastic wire located behind the filter screen on the top left. The sensor should be placed in a clip towards the front of the unit keeping it suspended between both the evaporator coils (the metal grating and copper coils you see) and the filter pre-screen and casing. If you feel comfortable you could check this and move the sensor between those two components yourself. I will need the serial number and the first and last name the unit was ordered under to check any further warranty options. Let us know if you were able to find the loose sensor or your order information. Have a great day.   Thank You,
Lauren
Edgestar Customer Service
i will probably try it tomorrow as it's not too big of a deal at the moment (relative to the work i have to do). thanks for the response though, how in the world did you know that anyway?
also, as i mentioned, this is a 450z which i think is a newer model? the site says 13,000 BTU's if it makes any difference
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by zley, posted on Jun 05, 2008
I am having the same problem with mine.  But it won't let me put the temp below 77 degrees either.
Comment by ronbegin, posted on Nov 30, 2007
I have had an AP410HS unit for about 3 months. During this time the unit has operated on the AC cycle only. Last week my son switched the cycle to heat and the unit operated for 10 minutes then stopped with the service memo "E1" I tried the reset button, washed the filter and the unit would start and run 30 seconds than stopped. I call customer service and wa told to send the unit back to the company and that's easier said than done since I live in Florida. Any idea what could be causing this problem?
Thanks You
Ron Begin
ronbgn@yahoo.com
Solution #1
posted on Oct 22, 2007
Not Rated (0)
Sea Breeze
Rank:Wiz Wiz
Rating: 78%, 91 votes
Behind the filter there should be a small metal tube that senses the temp. entering the unit sometime this is too close to the metal fins and sense the cold from the fins and not the air coming in. Make sure this is away from the fins and try a different temp. setting.And relocating the unit. These units tend to give off more heat that cooling because the hot air is returned to the inside of the room and not vented outside like window units.This is an  EdgeStar 12,000 BTU unit, correct?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Air Conditioners problems?
Air Conditioners
Air Conditioner shows error...
The AC this Summer some days... Answer This...
Air Conditioners
Vulcan gas wall furnace keeps
Vulcan gas wall furnace keeps... Answer This...
Air Conditioners
MY UNIT IS CREATING
my unit is creating alot of... Answer This...
EdgeStar 12,000 BTU Portable Air Conditioner...
EdgeStar 400S portable AC
Does not seem to cool as well... Answer This...
portable air conditioner 10000
I am looking for a dependable... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
