I've investigated this further and you might not have your phone set the same way as I have. To check, go into Menu, Settings,Application Settings, Call, All Calls ,Answering Mode and if Slide Up isn't available choose Any Key. I have mine set on Any Key and it works.I've investigated this further and you might not have your phone set the same way as I have. To check, go into Menu, Settings,Application Settings, Call, All Calls ,Answering Mode and if Slide Up isn't available choose Any Key. I have mine set on Any Key and it works.
You can't post conmments that contain an email address.
Open topic with navigation. Answering and Ending Calls. Manage settings foranswering and ending calls. From home, tap all apps icon Apps > settings icon ...
Open topic with navigation. Answering/Ending Calls. Manage settings for answering and ending calls. Press Home key and touch Menu key > Settings > My ...
You mean you want to open the network lock in your Samsung Tocco Ultra?You can approach Wickedunlock.com and get the unique unlock code by specifying the country,locked network.Based on the availability you can get the unlock code along with free unlock instructions.Once unlocked you can use it with a local sim in Africa.
this is simply the volume key on the left side of your phone.. it has a fake call feature when you press and hold the bottom button for like a fraction of a second.. you can deactivate it from phone settings :)
hi friend,
your phone have an option. like phone settings. go inside that option. there a one option like factory setting & reset option. there you need security code.enter your security code. your phone work as new phone.
if it not work again. then, go for update your mobile.which is provided on your mobile company website.
The problem with your phone is that the earpiece of your phone is bad, that is why you cannot hear anything while you call or if you are called.
All you need to do is to change the earpiece of your phone and you will see that after changing it, you can hear when people call or when you are called.
Replace the earpiece as said and you will see that your communication with other people on the phone will move smoothly.
Hi, just open your toolbar on the left hand side of the screen. Keep your finger on the music player shortcut and slide it across into your toolbar and it should move across into your toolbar. This worked for me ok. Hope this helps. Arnie.
