Question about HP Photosmart M425 Digital Camera
Memory card i bought a SDHC memory card and when put it in camera said wrong format what does this mean
  • donnamawston May 31, 2009
    not sure yet gona get 1 today thanks i will let u know
    Problem Solver:
  • 4 Answers
You might need the SD card, not the one that has HC also.
Posted on May 29, 2009
Nikon LL110 still says no more memory after formatting new card
Sounds like you have the wrong type memory card for the camera, check user manual and make sure you have bought the right type and capacity card.
Jan 27, 2013 | Nikon Coolpix S51c Digital Camera
How do i format the memory card on the kodak easy shareDX7590. I just bought and inserted a knew kodak 8 gm memory card and it says it need to be formated and i do not know how and have pushed all the...
To format a memory card, press the MENU button, use cursor-up/down to select Settings, press the OK button, use cursor-up/down to select "Format," and press OK.
The DX7590 works with MMC and SD cards. It does not work with SDHC cards. If you mean an 8GB card, then that's an SDHC card and will not work with the DX7590. The camera is limited to cards 2GB and smaller.
Sep 24, 2011 | Kodak EasyShare One Digital Camera
Got s205 coolpix and experiencing problem whnever i put in the SD card.. it always says. card cannot be read.. card that im using is a new one and it is 4gb.. dunno if the problem is in the cam or the...
Actually a 4GB SDHC card should be compatible with an S205, as that camera is new enough to work with SDHC. One thing to try before going through the below linked troubleshooting tips is if you have another card, try it in the camera. If the camera recognizes it, then it's likely that the card you purchased was defective, thus you should return it.
For others reading with similar problems, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 26, 2011 | Nikon Cameras
I've tried formatting a new san disk 4gb card and still reads "unable to use card" what do i do?
You haven't told us what kind of camera it is, but I can guess at the problem. There are two possibilities.
1. Your camera will only read SD cards, not SDHC cards. You've just bought a new memory card, not noticing that it was SDHC. The new cards don't work in your camera, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
2. You formatted the card NTFS, whereas the camera needs FAT32. You can format the card using Windows, but there is a complication: Windows defaults to "NTFS" when formatting, but memory cards normally use FAT32. Before you attempted this, you should have connect the card, and checked the 'properties' on the drive that appears. It probably said "FAT32". In this case, you could have gone ahead and formatted the card, but be sure that you chose "FAT32" from the drop-down list. If you format it NTFS, your camera won't be able to read it!
In this case your solution would be to format the card again, but using the FAT32 format.
You might find it useful to check your camera on dpreview (dot) com, and see if the memory card type is shown as just SD or SD/SDHC.
Jan 20, 2011 | Cameras
What does "memory card error" mean
It usually means that you are using an SDHC card in a camera that only understands SD cards. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If that isn't the problem, it may mean that your card needs formatting or has become corrupted, which will be fixed by formatting it. Formatting deletes everything on the card.
If that isn't the problem, then there may be a fault with the card or camera.
Dec 09, 2010 | Canon PowerShot A530 Digital Camera
Hi I bought 16GB SDHC Transcend class 10 memory card. I formatted on my computer (Windows Vista), but when I put in the camera it doesn't work, black screen. Please help me, why doesn't it work, am I...
You didn't tell us the model of your camera so it's difficult to say whether or not your camera will accept such a large card. I can tell you this, however, ....never format a card on a computer if you intend to use it in a camera. It puts the wrong operating system on the card. Always format in the camera. Try that and see if the card works.
Sep 26, 2010 | Casio EXILIM Digital Camera
I want to purchase an additiional memory card for a trip. Looking at SDHC 8GB memory card and it indicates "Card is compatible with SDHC Devices only" I don't know what this means. Are they compatible?...
sorry but the sdhc card wont work for that model... that type of mem card only works for compact cameras ( think higher/latest cam models).. so dont buy it, you will only get errors when u use it for ur camera and even if u format it over and over put it in put it out in out, still wont work
sdhc- high capacity memory card
Sep 12, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I bought a memory card for my kodak cx 6330 digital camera. When i put the card it in the camera,it says it need to be formatted, so i press continue, then it says pictures will be erased if formatted and...
Sorry, but a SDHC card will not work with your camera. Although it looks exactly the same as a standard SD card, the format the card uses is very differnet. Unfortunately your camera was designed before the SDHC format came out.
You'll need to instead purchase a standard SD card (those that are 2GB or less). Forunately these are very inexpensive these days, with 2GB cards going for around $6 with shipping:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=2gb+sd&x=22&y=18
Jul 10, 2009 | Kodak CX6330 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
HP Photosmart M425 Digital Camera Logo
268 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
