Question about Sony KP-57XBR10 57" Rear Projection Television
No Audio & Video red light blink continously.
No audio & video just turned off by itself then red standby light blinks continously. clicks as power cable plug, indicates power goes thru.
  • 744 Answers
Hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Posted on May 29, 2009
Sony klv-32s400A red led 8 time blinking.what is the eror.. Pls help
EIGHT Blinks
Problem with the audio (AUDIO),
unit goes to standby and blinks the self
diagnosis code. Check IC406 audio amp, PS401 and 402.
Aug 01, 2017 | Sony Televison & Video
The sense TV, red, flashing standby light comes on links, 10 times shuts up and audio video light comes.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 23, 2017 | Televison & Video
The receiver shuts itself, the red light blinks
The receiver is going into protect. Could be a number of reasons for it. Shorted amp, bad voltage regulators, etc. Would have to have someone look at it to determine the cause.
Mar 25, 2013 | Denon Audio Players & Recorders
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a sony Trinitron kv-32fs17 and i left ON while I was working around the house. The screen went OFF by itself. I tried to turn it back ON and all I got is this red light flashing. I unplugged the...
The flashing led will give the engineer a clue as to where the fault may lie.
The most common number of flashes is ... well here's a list.
Hope it helps.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Nov 14, 2010 | Televison & Video
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
There is a error in TV.Count how many times blinking the red light.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Nov 16, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Set powers off seconds after power on
* Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. That would be the fly back transformer and the horizontal output transistor.
Jul 14, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-57XBR10 57" Rear Projection Television Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
