Question about Canon DR 3080C Path-Through Scanner
Scanner pulls page in to just past the bottom sensor lever
The scanner feeds the page to just past the bottom sensor lever and then stops and gives a paper jam error. All rollers seem to be turning. However the user reported a grinding noise right before the scanner stopped feeding sheets.
  • 490 Answers
Please ensure that the rollers are clean and within its life span. (Rollers wear out and need to changed after 250,000 pages or as recommended by mfr). FAn the pages before scanning, Ensure the edge is trim with no folds or bends. The griniding noise is because the scanner has picked up more than one page.
S. Mohan. India
Posted on May 31, 2009
Error no page in Feeder when there are pages in feeder
Need more information. Does the doc elevator lift the paper to the pick rollers? Check the plastic lever that is attached to the upper feeder cover. Make sure the upper cover is closed properly Verify that the dark colored sensor is clean in the feeding tray
May 05, 2014 | Canon DR-9080C Path-Through Scanner
Up to two pages can be force fed through before the machine stops taking the pages and a paper jam error report is generated.
Inside the document feeder are two small levers near the middle of the paper path. One will be near the first roller to tell the machine that there's a sheet waiting to be pulled. The other will be an inch or two farther in, to tell it the paper has reached the scanner glass. If one of those levers is sticky, the machine will "think" it's feeding a very long continuous sheet. After a couple of feet or so, it reaches its programed limit and gives up to prevent tying up the phone line on an endless fax call when the document is jammed.
Open the feeder, find those levers, and make sure they move at the slightest touch. If one won't pop back up every time, it will give the symptoms you described. It may be as simple as a tiny scrap of paper wrapped over it, jamming it in its slot.
If the levers move freely, you may have a bad optical sensor underneath.
Oct 22, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Canon DR-5010C, only feeding 1 page at a time!
If you have it set to certain paper weights or manual feed that is all you will get. Change the settings from the printer monitor back to normal weight paper or text not high quality graphics and it should feed again.
Aug 10, 2009 | Canon DR-5010C Path-Through Scanner
Canon DR7580 only pulls one page then stops. Cleaned sensor to no avail.
First select count only mode and put a bunch, check if the roller/scanner is picking up and counting okay. If this is done, then you must check your software settings. May be your command is to scan only one page. If the scanner is not counting properly, then clean the rollers with a damp cloth. The ****** (bottom one near tray) roller must be cleaned ideally when power is off.
S. Mohan, Chennai, India
Jul 27, 2009 | Canon DR-9080C Path-Through Scanner
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
Feeding problem
There are quite a few optical paper sensors in any scanner. If one of them is blocked by a shred of paper, the scanners 'assumes' the paper is available and starts scanning. Try to blow air and clean the scanner. Take care not to damage the sensors. S. Mohan, India
Dec 24, 2008 | Canon DR 2080C Path-Through Scanner
Canon DR-3080cii paperjam
The 3 paper sensors are located along the center of the paper path. They are: Registration (lever type) on the bottom between separation & registration. Look for lever damage or torn paper. Scan Start (reflective) on the top between registration & front reading roller. Clean the sensor window with qtip & alcohol. Delivery (lever) at the eject roller. Same as reg, but harder to see due to location.The feed roller exchange kit is 6915A001. The rollers in this machine are not considered user replaceable.
Oct 09, 2008 | Canon DR-3080CII Path-Through Flatbed...
Incomplete feed
try correcting the page width and make sure one page goes through at a time also you can press the bottom of the paper and it will feed better
Mar 18, 2008 | Xerox DocuMate 252 Path-Through Scanner
No page was found in scanner when one was there
Lift up the black frame around the large soft grey pick rollers on the upper part of the paperfeed until it locks into place. Power off scanner and back on and the trya will lift and the paper will feed.
Oct 22, 2007 | Canon DR-9080C Path-Through Scanner
Canon DR 3080C Path-Through Scanner Logo
213 people viewed this question
old marine
old marine
