Question about Haier HWR12XCB Air conditioner
Hot air only no cooling
Will only blow hot air no cooling at all
  • 744 Answers
Hi..
As more and more moisture condenses the water begins to drip down into the base of the air conditioner where it is evaporated to the outside of the house.... so the problem might be in ur evaporator coil.. try replacing the coil if u are an expert or else with the help of technician try to fix it..
thank u
rate me
Posted on May 29, 2009
PTAC UNIT BLOWING HOT AIR IN COOLING MODE
Hot or warm? Sound like float switch shuts compressor off. Vacuum the drain and clean the pan
Aug 24, 2016 | Heating & Cooling
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
2005 escalade rear a/c blowing cool air .front a/c blowing hot
More than likely, you have a blend door actuator problem. Locate the faulty actuator under the dash, usually on the firewall, and replace.
Jul 19, 2010 | 2005 Cadillac Escalade Esv
Ive got an amcor air conditioner, will it blow hot air aswell as cold,
If it blows hot and cool air, it means that you aircon is
not having an isolation of the evaporator and condenser
air. Please have a technician repair the air leak. Hot air from the condenser must be separated from the cool air
of the evaporator. Hope this will help you.
Jan 04, 2010 | Amcor PLM-14000E Portable Air Conditioner
Hot air blows but cools down in 15-20 seconds.
You likely have a restriction in the heater coolant hose circuit - perhaps a coolant control valve not fully opening, or a kinked hose.
Insufficient coolant volume is flowing to keep the heater core hot.
Try back flushing the heater core system with a garden hose to check flow.
Nov 13, 2009 | 2003 Audi A4 Cabriolet
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
A/c and heater
Is it leaking antefreeze?
The thermostat might be gone or needs a bigger thermostat
It could be a vaccum leak for the drivers side blowing cool air and the passenger side blowing warm air
Does it have dual air control switches one for drivers side and one for passengers side?
Oct 28, 2008 | 2003 Pontiac Grand Prix
My Dimplex DAC12AC aircooler is blowing out hot air
Hi,its possible have a problem your PCB Board ,the 17c is so cool setting but blows hot , and the E3 simble its min High Cooling , pls check ur PCB board to the nearest service center.
Jan 07, 2008 | Heating & Cooling
Haier HWR12XCB Air conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
