Question about HP Photosmart C6180 All-In-One InkJet Printer
Print sharing i did download driver for my hp psc 6200 series during installation, a point is reached to decide whether connecting to network OR via USB i want to only "share" this printer, not really set up a network what settings must i use on my desktop (dell windows vista) and acer one netbook(windows xp) i have a dsl modem and wireless router for my netbook connection please can somebody help me thanx in advance
  • 489 Answers
No matter how you slice it, if you want to share the printer, you will be creating a network. If I remember this printer correctly, it has an Ethernet port to connect to a network or USB to connect ot a computer. If your router supports wired connections, you can connect it there and just inistall drivers on each device and selec tthe network option. If not, you will probably want to connect it via USB to your desktop machine and enable print sharing on that machine. Te enable printer sharing, open up the Network and Sharing Center. In the Sharing and Discovery section, turn on the option for Printer Sharing. You will still need to install the XP driver on the netbook and select the network option, but give it the proper network location (ie.\\mycomputer\this printer).
Posted on May 29, 2009
I have an HP 6200 pro desktop that I am having trouble finding the correct drivers for the 82579LM Gigabit network Ethernet connection. Can you Help?
what you need to know is what operating system does the hp 6200 pro desktop run on ?
from the specs on the hp 6200 pro desktop
it might be
Microsoft Windows 7 Professional 32-bit
Then download the correct driver for the operating system you are using
https://downloadcenter.intel.com/product/47549/Intel-82579-Gigabit-Ethernet-Controller
and then either run the download or point the update driver to the folder the driver is downloaded into .
Depends on the type of driver you download as to whether it installs itself or has to be added via updating the driver and pointing to its location after it copies its extracted files if it is compressed.
Apr 29, 2017 | HP Computers & Internet
Printer HP Photosmart C5180 Series cannot be contacted over the network
Check with HP for a Windows 7 driver for the printer. HP Ink Jets require proper drivers to work correctly. Once you have downloaded and installed the drivers try connecting again.
If you have installed the drivers and Windows 7 still refuses to "talk" to the printer, you may have to adjust your advanced network settings as well. Open up the Network and Sharing center, click on advanced sharing settings and make sure file and printer sharing is turned on. Also check "File Sharing Connections" and enable file sharing for devices that use 40 or 56 bit encryption.
If that fails to work you may need to speak with HP support for further assistance.
Feb 23, 2012 | HP Photosmart C5180 All-In-One InkJet...
My wife has a laptop and she connects to the internet via wireless router. She sometimes needs to print. We have a HP PhotoSmart P1100 that connects directly to my computer. We have lost our original...
Normal 0 If you printer does not have a built-in network card then for the laptop and computer to print via wireless to this printer either then, the printer needs to be connected to a print server or setup as a shared printer. A shared printer is the cheapest and easiest option. Please click on this link and follow my instructions to setup a shared printer :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Oct 23, 2010 | HP Computers & Internet
I want to setup to print wirelessly from my laptop to my hp psc 1410v all in one
This printer model does not support wireless printing. If you have connected this printer via USB cable other computer, then we could share the printer to you laptop wireless;provided the other computer is in same wireless network.
Aug 20, 2010 | HP PSC 1410v All-in-One Printer
Can the HP PSC 2410 printer be shared between 2 computers?
generally the printers with single USB port are dedicated for use with one computer.
However, depending on the way you connect the computers you can share the printer with more than one computer.
1. SET THE SECOND COMPUTER UP AS A NETWORK PRINTER
This is one of the most common ways to connect two home computers to the same printer. The advantage of this technique is that it doesn't cost you anything extra. You do require some computer literacy in networking though.
Firstly you physically connect the first computer to the printer via the provided cables. The second computer now needs to be set up as a network printer to have printing capabilities. The computer not physically hooked up sends a message via the network to the computer which is physically connected to print.
To set up the network connection in Windows follow these steps:
-Open the control panel
-Select the network or network and sharing icon
-You should see an icon named file and print sharing or simply print sharing. Turn on printer sharing if it is off.
(This requires your two computers to already share a network connection; otherwise you will have to set this up).
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/print_sharingw.mspx?mfr=true
2. PURCHASE A PRINTER SWITCH
A simple old fashioned way to connect two computers to one printer is by hooking them up to one switchbox in the middle. This switch is what is connected to the printer. This is a similar method to using a router to distribute the Internet to more then one computer.
This method is good for people who aren't very computer literate when it comes to networking. All you have to do is plug the cables in and off you go. However, it has one large disadvantage which is that the computers and printer all have to be in close proximity for the cables to reach.
The printer server should support the printer so that you can get maximum functionality from the printer device (including the multifunction feature).
http://cgi.ebay.com.au/Gray-Steel-Two-Ports-Printer-Sharing-USB-Switch-Box-/180502082365?cmd=ViewItem&pt=AU_Computers_Printer_Accessories&hash=item2a06c3333d
3. You can buy a printer server but for that you need to make sure the device fully supports the printer you have got including the multifunction features. Both computers will need to have network connection.
Something like http://www.netgear.com.au/au/Product/Print-Servers/Wired-Print-Servers/PS121
or
http://www.belkin.com/IWCatProductPage.process?Product_Id=354892
May 07, 2010 | HP PSC 2410 All-In-One InkJet Printer
I've aquired a Hp office jet 6200 series all-in-one.I have a Dell Inspiron2200 laptop.Ihave wireless internet access on my laptop.Is it possible to download from the internet what I need to know and do so...
It looks like it isn't an hp wireless printer. You can connect to the printer via a usb cord and download the software from HP if you want to. Another way is have the printer connected to a wired computer via usb and share the printer and then with the other computer on you could print pages from the wireless laptop to the printer.
Jan 11, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Using multiple HP printer models with same Windows XP laptop
I doubt there is a universal driver , however you could connect directly to your pc or via a router and share it over your home /business network, and access it them that way
Feb 13, 2009 | HP Office Equipment & Supplies
HP psc 1315 tries to downloads wrong drivers
HP has two sets of numbers for the printer.
1315 - This is your model number
1300 - This is your series number
The software, manuals, printer queue, etc. will all show the printer under your series number. This is because there are several models that have minor differences that are not related to the software so they will all share the same software. When you try to download the software for your OS you will use your model number and when it has downloaded during the install it will all show as the series number again. This is normal.
Jan 14, 2009 | HP PSC 1315 All-In-One InkJet Printer
Can't get psc 1610 to print on new macbook wirelessly
If you install the Hp wireless driver on your Mac, that should do it.
Aug 18, 2017 | HP PSC 1610 All-In-One InkJet Printer
Need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Jun 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
