Question about iLO LCT32HA36 Television
Voltage regulator I was told I needed a voltage regulator. Is there an easy way to replace this? They wanted to charge me 260.00 dollars
  • 12 Answers
If you know what voltage regulator is broken then its an easy fix. But for $150 you buy a knew power supply so i don't really think its worth paying $260 for them to fix a small part like that, but if you are going to work on it make sure you know what you are doing and be cautious because capacitors can store a great amount of voltage even after you turn of the tv.
Posted on Jun 21, 2009
Checking or replacing stator
OR A VOLTAGE REGULATOR,IF THE STATOR IS BAD,IT WONT CHARGE CHECK THE FUSE,BATTERY CONNECTIONS ARE CLEAN,ALL WIRING IS TIGHT, AND HAVE VOLTAGE REGULATOR CHECKED.
May 30, 2014 | 2003 Suzuki GSX-R 750
I have an 86 toyota pcickup battery charge light is on have good battery and replaced alternator twice.
i think you have an external voltage regulator in that year , ck that first . The easy way to tell if it has an external regulator ,if it has carburated it has an external regulator if its fuel-injected its internal regulator in side the alternator.Have you checked to see how much voltage the charging system is putting out at an idle ? It should be around 13.5 volts to 14.5 volts any less then 12.5 charge light won't go out.
May 05, 2011 | 1986 Toyota Pickup 4WD
Where is the voltage regulator?
the voltage regulator is built into the altenator,if you are having a charge problem, theres an easy way to check to see if it;s charging, while the engine is running disconnect the positive side post of battery, careful not to ground it to anything metal, if car dies,no charge from altenator, if it stays running,reconnect the positive post, if not you'll need to leave that disconnected to replace that altenator.if you need further assistance from fixya please post your question and we'll be happy to help you.thank you for choosing fixya.com!!
Nov 21, 2010 | 1993 Dodge Dynasty
I put a 99 3.2 dodge Concorde engine in a 01
You cannot run an external regulator on this, your only solution is to replace the ECM.
Dec 02, 2009 | 2001 Dodge Intrepid
I have a 2004 Mazda 6 with the 2.3 liter engine. I have replaced the altenator 4 times and the battery twice because the battery light comes on and the transmission shifts to the 3rd gear. When the...
Could be a eloctronics fault! Have a reputable autolect.shop do a diagnostics check, alternativ solution fit a Bosch replacement alternator.
Regards
Phillip
Sep 12, 2009 | 2004 Mazda 6
Voltage regulator
Voltage regulator is built-in to the alternator assembly.
Have you tried replacing the battery?
A battery with a shorted cell will not charge properly and may even damage an alternator or regulator.
Note1: use a digital voltmeter (about $25 at Lowe's or Radio Shack) and check voltage across batt terminals while engine running. If more than 12.6 Volts DC and more typically about 13 Volts, then the alternator is working.
Note2: from Jan 98 to May 98 shows a different part # alternator than June - Dec 98
check the manufacture date on your driver door edge.
Oct 25, 2008 | 1998 Mazda Protege
Charging system
you can also try to instal a external regulator, from the 70,s or 80's but that will be like a good mikey mouse job,
if you can't affort to pay that money now, the only way is visiting auto electrical shops and ask for an external regulator, if they don't want to do it i will tell you how to do it, but if you want it original then have the computer replaced, but before replacing teh computer make sure you are getting igniton power to alternator at one of the small thing wires,
i will aprecviate your ranking and good luck
Jun 23, 2008 | 2004 Dodge Ram
iLO LCT32HA36 Television Logo
191 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
