Question about Canon Office Equipment & Supplies
Black picture the lamp does't lit. no error message.
The machine is canon np 6317 it warms up as normal but if i print it gives out the black paper because the exposure lamp is not lit and the machine is still doesn't show any error. i replaced the lamp by new one but the problem is remain the same. what else must i do?
    President:
  • Canon Master
  • 990 Answers
Hi sir;Try to make a copy with open cover ( check the exposure lamp is on), if exposure lamp not on andyou already replace a new one then check the thermos fuse at the end of the lamp, replace that one.
Posted on May 29, 2009
HOW DO I FIX THE PAPER JAMS?
click start , click devices and printers, right click printer image, click trouble shoot and follow directions.
Jul 09, 2015 | Canon NP 6317 COPIER FOR 220 VOLTS ONLY
How to fix counter error on canon np 6317
Again, go to site on line, you will fine
they have all error numbers.
LUCK
Dec 17, 2014 | Canon NP 6317 COPIER FOR 220 VOLTS ONLY
Notes on error 030 on canon np 6317
Hi
This error code refers to "Total counter disconnected or open" but doesn't give an immediate solution (one assumes reconnection would clear it.) The page can be found here:
Error Codes Canon NP6317 Code E030
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
E 210
there is an lance home position sensor problem... open the platen glass, then open the lance cover (black Metal).. then turn on the machine and check the lance is moving forward and back to center.... if not clean the lance home position sensor or replace that.....
Nov 28, 2011 | Canon NP 6050 Copier
I have an E0 code
Check the main thermistor,the thermal switch,the heater lamp.This components it is in open circuit.Reset the error code in service mode.
Sep 27, 2009 | Canon NP 6551 Black and White Copier
E002 canon 6317
E002
1)due to fuser unit temperature control fault.
2)try to reset the machine by tuning on and off
3)fixing thermister or thermoswitch faulty due to cannot maintain fixing heater temp causes E002 appear.
4)check any paper roll over the surface of fixing roller.try to remove it.
5)fixing roller or fuser roller located near to printing output.
Jun 10, 2009 | Canon imageCLASS D761 Copier
Canon NP 1215s photocopier error code E0
did you check thermistor, I think that you have a problem with thermistor, not only thermoswitch! what about black copy - did you check is expo lamp (under the original glass) is lighting or not, if not - it's normal to have a black copy!
Success!
Jan 03, 2009 | Canon NP 6551 Black and White Copier
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
157 people viewed this question
old marine
old marine
