Question about Toshiba 51H94 51" Rear Projection HDTV
Fan stopped working
My hdtv has a message that will not go away on it its say the fan stopped working for the cable card what do i have to do now
I have the same problem... just started last week. if you found a sol'n, please post or email me. Thanks... I'll do the same
Posted on Aug 03, 2009
Tv states the cable card fan is not working
Well the issue is that one of the TV's fans isn't working. It doesn't matter if you have a cable card in the slot or not, the fan still doesn't work and the TV's self diagnostics is picking that up.
The answer isn't to deal with the message. It's to get the fan fixed. That's also an easier fix than trying to somehow hot-wire the TV's self diagnostics so it's blind to errors. It'll be a little mini fan maybe an inch to inch and a half square that costs less than $10. Go the simple route.... just replace the fan.
Sep 11, 2014 | Toshiba SELECT 62HM196 Rear Projection...
My HP desktop fan turns on as does the green light, but there is a constant beeping sound and no display on the monitor
This error message mean that there isn't video signal from the video card going to the monitor.
Try reconnecting the video cable to the monitor. If this does not work then you may have a faulty video card.
Sep 18, 2012 | HP Pavilion a1410n (ER890AA) PC Desktop
Hitachi rear projection hd tv. message on screen says invalid cable card installed. remove to restore video access. there is no cable card installed as we have cable service through a cable company. j
Two things to try here---first is unplug the set for a while and plug back to see if the microprocessor in the set will reboot.
Second look to see if slot for the card has anything at all in it or is dirty.
if dirty blow it clean and repeat unplug procedure Note: very few of these sets have a hard reset feature but if all else fails call Hitachi customer service with the model number---they have some very good people answering the phones and an extensive data base on sets/problems.
Apr 11, 2012 | Hitachi 57F500 57" Rear Projection...
917-Front Audio Not Connected
Please connect front audio cable with motherboard in the a audio port of motherboard.If we work with sound card then connect front audio cable with sound card.
Feb 12, 2011 | HP Compaq dc7100 PC Desktop
I'm getting a message on my screen that the fan stop working
the fan at the back of your tv casing is the exhaust fan..it regulates the temp. of your tv and it coolens the electronic component.....it's a warning sign means u need to check if still running, if not replace a new one...when neglected could result to damage in power supply..
Feb 11, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Our Sony TV issues a loud fan noise from the rear of the TV. This has happened in the past, but with a few cable checks...it goes away. This time, it only stops after we turn the TV off. What is the...
tv's are designed with a fan system to help dissipate heat from the internal electronic components. The fan noise may appear to be louder when mounted or installed in an enclosed area. try re-positioning the television. It may help reduce the fan noise
Dec 24, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Won't boot....fans start, then stop right away
check if your power source is ok. it may be broken and this is why you hear the fans start and then stop right away. they are working about 3-4 seconds, aren't they?
remove and put back the jumper for clear cmos after you test your motherboard with a new ac source
Jan 25, 2010 | Biostar P4M900-M4 Motherboard
Pt-44lcx65
You have to hold the Stop/Swap button for 7 seconds.
May 21, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Toshiba 51H94 51" Rear Projection HDTV Logo
279 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
