Question about HP Compaq Presario C762NR Notebook
Hp c762nr will not boot and blacklight will not come on when on
Hp c762nr will not boot and blacklight will not come on after i drop my iron on the keyboard area by accident. hard drive fails to boot. it booted once after the drop but backlight would not illuminate screen. now will not boot at all and backlight will not work either
  • cavanaughdes May 29, 2009
    no luck. not even system bios will come on. i think the impact did some real damage. no boot to bios and no screen
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Open the back case of Hard and Memory..remove the hard drive then remove the memory...after u remove the memory try to clean the memory using a paper eraser then put it back the memory.about hard drive/Hard Disk do not put it back only memory to test and run the unit.if unit is back to power on self test try put it back the hard drive/HDD then try boot all system.if their is message hard fails i think u need to try to replace the Hard Disk...Thanks and Good Luck...GOOD DAY...
Posted on May 29, 2009
Replacing inverter on Compaq Presario C762NR Notebook PC
Here is the manual for your model laptop. Information regarding the inverter (HP Part # 454915-001) and how to disassemble and replace the part begins on page 55.
Thanks, and have a great day!
If my solution helped you, please don't forget to leave positive feedback!
Aug 29, 2011 | HP Compaq Presario C762NR Notebook
My compaq presario C762NR Notebook PC is not connecting to the internet. My connection is very strong but the pc says "Connection status: unknown. The dependency service or group failed to...
wow, posting with NO OS stated, no Operating system stated.
windows what?, OS2, Linux, what? be specific or help will not be correct.
connecting. we don't know at all what connections you have,
none stated?
is this an Ethernet cable (cat5/6-RJ45) ? to your ROUTER?
or wifi to your home router, what?
if Ethernet cable works and wifi not then we know is wifi only.
why not use a cable, buy one for $3 and keep it handy.
btw , the cables allows getting long winded windows updates 100x faster. or if installing an new or updated or restore OS even faster.
we have no idea at all what OS is there.
nor if it was upgraded to a higher version without HP support.
its and HP computer now, Compaq is gone.
if you look in DEVICE MANAGER.
see all net work chips there, ?
are all of them happy, no red, no yellow marks or missing ?
if yes, then your DRIVERS are wrong, or corrupted.
that is step one,
not get connected. get connected can not fix bad drivers.
so DM is first.
but first first is what , DRIVERS matching your unstated OS.
Apr 29, 2017 | Compaq Presario C762NR Notebook
The screen goes blank soon afte 2 seconds but put a flash light on the frount you can see it is this the blacklight
image with no blacklight could be sign that the backlight (fluorescent tube) is faulty, may need to have that serviced
Mar 02, 2011 | HP Pavilion F1703 17" LCD Monitor
I have a Compaq/HP Laptop Model C762NR and I have found an intermittent cable I need to replace. I am looking for a cable that is bundled and connects from the motherboard on the left side, then runs...
this LT is a relic, there are no new parts
so go to EBAY, see that LAPTop there, what you see there is all you get. or wait for 6months each day checking, for hard to find parts.
that is and LCD cable simple ./
there is no HP(compaq) support on any pc this old.
leaving only the used parts market./
google that yet, like "compaq, laptop parts"
its like having a real old car, and needing parts.
hard to find, yes.
Jul 10, 2017 | Compaq Presario C762NR Notebook
My keybored will light up and everything but wen i turn fone on i cant see menu just blacklight
Possible failrue of the display unit. removve the panel and check the conection to the display. If there is any signs of the display coming on when the connecctions are touched clean and carefully look for any loose connections. If so use a thin iron to touch up the solder.
helpful?
Aug 29, 2010 | Cell Phones
My wife dropped her computer and the plastic surrounding the keyboard cracked. The cover and everything else is ok. What is price for the plastic cover arround the keyboard? Is it difficult to replace?...
Well it is a bit of a mission to replace, however if you get yourself a Service manual, for your exact model, it will make it a lot easier, as for cost, less than $100.00 But I would check out eBay or shimmy up nice to your local PC repairman and you may even score one for nix... many of us have old laptops cluttering up the place that we would gladly give away to get some space back. GL
Feb 24, 2010 | HP Compaq Presario C762NR Notebook
Compaq presario C762NR notebook pc I have trouble charging it, the blue light turns on and off. Once I plug it in I need to move the charger around in order to start charging
You either have bad wires or loose connection. Take the prongs on the plugin and bend them both outwards. Use wrench if needed. Bend them just enough so they will stay in the outlet without being loose. This is the most common problem with charging
Jul 19, 2009 | HP Compaq Presario C762NR Notebook
Remove battery
I suggest you go to HP/Compaq website and download the manual.
Aug 26, 2008 | Compaq Presario M2000 Notebook
HP Compaq Presario C762NR Notebook Logo
176 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
