Question about Invacare Supply Group Invacare Pronto M91 Electric Wheelchair
Batteries won't charge w/ on board charger-+
I replaced the batteries, then reoplaced the on board charger. The "charge full" light comes on as soon as I plug it in. The meter on the chair doesn't move, although it did in prior weeks showing some activity. Currently I use 2 car chargers to keep me rolling. Any suggestions? I have a jazzy 1103 mini
  • 32 Answers
Sounds like blown fuse which is at rear of chair. may be underneath rear cover. this fuse wont keep the chair from working, however, it will keep the charging from working.
Posted on Jul 12, 2009
SOURCE: Jazzy 1103 The led charge indicator quit months
turn it on then push the joystick forward till it beeps then pull it backward till it beeps then it will unlock. chair is in lockout mode
Posted on Jun 16, 2010
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 175 Answers
SOURCE: Replacing battteries in Jazzy 1103 power chair
Here's a quick link to the owners manual for the 1103 that will show you how to replace the batteries on your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_1103_Ultra_om.pdf
Posted on Oct 22, 2009
  • 5 Answers
SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Posted on Jan 28, 2010
  • 11 Answers
SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
Posted on May 16, 2010
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Got a replacement battery not long after I bought this weedeater. The replacement battery would not hold a full charge [unless it is supposed to last only 10 minutes]...however, I lived with it. Well now,...
The replacement battery should have come with a WARRANTY, e.g., 30 days or 90 days or 1 year.
Exercise that warranty to get it inspected/repaired/replaced.
How old is the weed-eater? Has its warranty expired? It could be a problem with the battery-recharger.
Jun 06, 2011 | Computers & Internet
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
My s032 dont seem to hover very well and back and forward dont work very well
are you sure the battery is fully charged the light on the charger
should shine brightly but you might of overcharged it if you have had it on for 90 mins
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
The battery wont stay charged .when you plug it in to charge the green light comes on ,when fully charged the red light is on,when you turn it on no power
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Mar 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
May 29, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
Battery life
buy an in car charger then take it back to store if its new,theyshould reair/replace it.when you get home from your holiday but the charger should see you home anyway....
Aug 09, 2007 | Coby TF-DVD7005 Portable DVD Player
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
5,134 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
