Question about 3M SportsStuff Speedzone 3 Inflatable Towable
Airhead UFO will not spin
We have tried to get this inflatable to spin using various methods, but no luck. Anyone have success with this inflatable getting it to spin?
Im trying to figure out how to inflate the trek 4900 tire, its not your normal valve stem and i havent found anyone that know please help me?
Where did you look? Search for "inflate bicycle tire" or "inflate presta valve".
Search engines work for most common questions - immediately.
Aug 04, 2011 | Trek 4900
HELP! My new little 200 boat will NOT INFLATE! Have tried everything. I had another one that inflated immediately and this one will not! it is as if it has no way in the valves for the air to get into...
Hi, perhaps the problem may lie with the inflating method. Have you checked to see if the pump is actually giving air? These rafts usually have multiple bladders, are they all giving you this problem? Also, there is a plastic flap at the inside the base of the valve to prevent too much air from escaping before you plug it. you mush insert the air chuck adapter past this point. Good Luck!
Nov 10, 2010 | Intex Excursion 4 Inflatable Boat Set
Our Intex air bed has a leak, we think the leak is in the valve. over night the bed deflates, ugh.
Guerilla repair it by replacing the valve by cutting out the valve add a new valve with extra rubber and, rubber cement.
Dec 22, 2009 | Intex AIRHEAD Performance 1-Person...
What is the best way to patch a small hole in a towable tube
Your local sporting goods store should carry a patch repair kit that should work perfectly.
Sep 09, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Airhead 3 person tube
Put weight (people) on the rear of tube as far as possible and start out at full throttle until they are moving sufficently to stay on top of the water. Make sure tube is fully inflated.
Aug 09, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
Feb 16, 2009 | Olevia LT42HVi 42 in. LCD Television
3M SportsStuff Speedzone 3 Inflatable Towable Logo
123 people viewed this question
Top 3M Water Sport Experts
Tom Chichester
Bill Boyd
Are you a 3M Water Sport Expert? Answer questions, earn points and help others
