On occasions the GPS positioning goes out by up to 100 yards often assuming I am on the wrong road. System then resets itself and works as normal. This happens on a regular basis. Is there a way to re-calibrate the GPS position to prevent this happening again ? Please help
GPS is prone to location errors caused by terrain or buildings but this is quite a large error!
It could be that you are not receiving enough satellites and you may need an external antenna on your car or reposition the receiver.
You should be getting at least 5 satellites with a good signal to get an accurate position
By bogdan_nita1 on Oct 18, 2009
VDO Dayton 5,8'' Monitor MM5000 The display is broken- u can see only 1/3 of the screen
Salutare ! Este monitor complet de vanzare . 150 euro . Relatii pe mess : [email protected]
I found this when I googled vdo ms5000. part one of installation is - http://autospeed.com/cms/article.html?&A=0876, and part two is - http://autospeed.com/cms/article.html?&A=0905 hope this helps. Craig
What is the SW Number?? - SETTINGS>SYSTEM INFO.>CONFIGURATION. Anything below 0760 should be updated.
To change the screen press the Menu button on the top of the monitor 3 times then press the + button 2 times. Should now be in 16:9.
