Trouble installing print cartridges on the HP 1315
Hi, in the course of addressing a "print cardtirdge stalled" message on my HP 1315, I removed the cartridges. When I plugged everything back in and attempted to re-install the cartridges, they wouldn't go back in. The pieces that are on top of the catridge holders that are usually poopsed up are not up and I can't figure out how to release them so get the cartridges back in. Hope t his makes sense. Can you help?
Thanks.
  • 3,600 Answers
You have to shove them up, put the cartridges in at the bottom first, you just shoved the locking mechanism down buy acciden't
Posted on May 29, 2009
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Will not print in color
So it never worked?, return it, run the utility first that is on either the disk or the website
Dec 20, 2008 | HP PhotoSmart 1315 InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Trouble shooting my printer all in one 1315 series
    You need to clean the rollers in the back panel of the printer.
    Unplug the printer while it is powered on and remove the back panel. Get a damp cloth (not too wet) and wipe off the rubber rollers in the printer as well as on the panel. Replace the panel and plug printer back in. It should come on by itself and initialize.
    Print a page from your computer. It should now only feed a single sheet at a time.
    Jul 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
    HP PSC 1315
    Yes you need both the cartidges
    Jul 25, 2008 | HP PSC 1315 All-In-One InkJet Printer
    HP PSC 1315 All-In-One InkJet Print Cartridge Error
    Hello -
    Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
    Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
    Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
    That should help, if it was the 1315 model.
    That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
    Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Dell 720 printer
    Disconect the printer form the computer usb port.
    Open the cartridge access door. remove and reseat cartridges. Move the carriage manually.
    Dec 21, 2007 | HP PSC 1315 All-In-One InkJet Printer
    Cartridge stalling and black cartridge not printing ink
    The first suggestion is to buy a no remanufactured cartige, buy an original HP 28 ( I think is the number for black)
    malox
    Nov 12, 2007 | HP PSC 1315 All-In-One InkJet Printer
    jasbo
    jasbo
