Question about Samsung Televison & Video
Tv makes loud noise in the area of lamp
Tv makes loud noise around area of lamp
  • Anonymous Mar 17, 2014
    tv making a loud statick sounding noise
  • 744 Answers
Hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Posted on May 29, 2009
TV was dark in color then made loud Popping noise and now no picture on TV
You don't indicate model or brand, sounds like you may have an LCD projection tv. If so find the lamp housing area, remove the lamp. You may find that the anode of the lamp has fractured. You can by your model # find replacement lamps on line. I use niosales on eBay for lamps, always good quality , priced right and free shipping!
Jul 09, 2011 | Televison & Video
Bulb has gone out and now makes a loud noise
The noise depending on where it came from may be normal. You wont be sure unless a TV repairman checks the boards to know for sure, or you could replace the bulb and hope for the best.
Jul 19, 2010 | Panasonic PT-56DLX75 56" HDTV
Tv making a loud noise and the lamp status light
Replaced the lamp.Might also be light engine blast too.
Dec 17, 2009 | Televison & Video
Loud noise coming from Lamp area
The fans in these generaly do not go bad, the part nubmer for the lamp cooling fan is 265943. But my guess is that the color wheel is starting to go out of you light engine. I am not sure if these are still avalable but the part nubmer for it would be 267888. Worst case you could send your engine in for repair engine nubmer should be 265864 or order a repacement try this site. GOOD LUCK http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD50LPW165 50" Rear Projection HDTV
My tv is making a loud roaring noise in the back
I had the same problem, it was the color wheel (part # 270916). The bearings go and it starts making noise. It was fairly easy to replace.
Jan 16, 2009 | RCA HD50LPW175 50" HDTV
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
Televison & Video Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
