Question about Philips Magnavox 42MF521D/37 Television
No pic or sound
I have a big screen tv and after turning it on one day the picture and sound are m.i.a. the screen stays blue the channel numbers will show up and the menu shows up fine. but no sound or picture. Now if i put it in the pip and have one on main and the other on a different input source I can get a picture on the half of the screen but no sound and no pic in the pip box. Can I fix this or should I get a new tv? magnavox 42mf700017
    President:
  • 4,402 Answers
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. No pic or sound - mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
On TV1 screen stays blue and no sound go to AV1 DVDplayer have pic and sound The tv was given to told it worked is it a code
Did you scan for channels after hooking up the antenna?
Have the tv scan for available channels in your area.
Should be on the tv menu to scan for digital or analog channels.
Feb 05, 2016 | Olevia LT27HVX 27 in. LCD Television
Jvc no power when plugged in
you tube might have blown ouy that's a big problem.Next time make sure you plug your TV in a surcharge protector
Nov 12, 2012 | JVC LT-37X898 37 in. TV
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen turns off/screen tuns blue
Good Day, rbls;
This is a generic description of a common concern of this type. 90% of the time if the pic turns a color then turns off it is the picture tube.
If the picture is lost and the pic/screen turns blue it is normally a lost of signal from the TV's source (cable box, vcr,dvd & etc), check all cables, try different inputs & etc.
Good Luck, big IRISH. For more detail e me at mmrkcar@yaoo.com
Jul 15, 2008 | Televison & Video
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Mitsubishi ws65613 no picture or sound, blue screen only
Good Day;
Blue screen that has gotten worse over the past few days, I would suspect fluid on your signal board.
The three CRT's in the TV has coolant that tries to keep them cool but they have a problem with the 'glycol' leaking out of it's chamber.
Take speaker grill off, remove panel and look on the right side of opening. Look for fluid on the board, shinny substance, it's hard to see so look closely. That is the most common problem.
2&3 are the CRT's or the CRT's drive circuit.
Good Luck, Day,let me know, Big Irish.
Jun 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Philips Magnavox 42MF521D/37 Television Logo
175 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
