Question about Kenmore Kitchen Ranges
Oven not about 100 deg. below temperature setting
I have an approximately 3 year old Kenmore electric range model 790.96412407. Within the past month or so the oven has not been heating properly... if you set the oven to 350 deg. at the end of the preheat cycle a thermometer only shows 260 deg. This is new behaviour as this oven has always if anything been a bit too hot. I tried changing the oven temperature sensor but that did not solve the problem. Both the old and new sensor show 1090 ohms resistance at room temperature. I am guessing it is either the bake element or control board that is the problem but dont know how to eliminate one or the other.
  • Kelly Ziadie May 29, 2009
    Thanks for the quick reply. The element shows continuity, and after removing the bottom panel (this is a hidden element model), and turning the oven on, all parts of the element turn a uniform red color. Would you say then that the control board would be the problem, or am I missing another possibility here?
    I am a bit hesitant for 2 reasons. One obviously is the cost of the control board. The second, which is more disturbing, is that when I started researching this problem on the internet I came across a multitude of stories of Kenmore model 790 oven elements heating out of control to the point of catching fire, sometimes without the unit being turned on from the panel. Although I have never seen any symptoms close to this, I would be messing with the same components.
  • 21 Answers
It's easier to eliminate the element.You can do this two ways;first thing,remove power from unit.Unplug it and you know for sure power is off.Inside the oven you can get to the wiring on element by removing the two screws on the back wall that holds the bracket to the wall.(this works for both elements)Pull the element out and you will see the wires(2).They will be either screwed on or connected with spade clips which pull on/off.Remove at least one wire and use your meter,set on ohms, put a meter lead on each element connector,you should read continuity.If you don't the element is bad,replace it.Give the elements a good visual inspection first,some times you can see where the element burnt out.The other way to get to the wiring by pulling the back panel off the stove.Hope this helps. Gregg
Posted on May 29, 2009
Elite dual fuel range/oven. Why isn't it heating past 100 deg and burner igniters do not spark?
sadly it sounds like you need to call a service repairman . being an appliance that can explode I do not suggest you try and fix it yourself .
Oct 27, 2015 | Kenmore 30" Slide-In Dual Fuel Range...
Why is a Kenmore elec range model 665.92004102 have oven temp lower by 100 deg at settings of 400, 450, 475 and 495; while off 150 at 350 deg setting?
There is a problem with the oven probe sensor or EOC. To ensure this problem is fixed both parts would need to be replaced. This could cost more then $300 to have repaired.
Apr 23, 2014 | Kenmore 95822 / 95824 / 95829 Electric...
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
My Kenmore electric range oven, model 790.suddenly stopped working while I was baking at 400 degrees. The coil burners still function correctly but the touch 'panel' which controls the oven...
The oven is controlled by a separate circuit in relation to the coils. That is why your cook top operates as it is independent. If the Oven controls are failing to work, it could be that the circuit board has shorted out or a fuse has disconnect operations. This requires a professional technician with the proper test equipment to trace down the problem.
Jan 30, 2018 | Kitchen Ranges
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven and brolier will not work
The problem lies within your oven control board. This is very common and are not very hard to replace but they are expensive. You can check the price of a new control board at sears parts.
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Jenn-Air Convection Oven
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has a very dim display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and what it may cost us?
Dec 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Self cleaning oven instructions
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
May 26, 2007 | Frigidaire FEF352 Electric Kitchen Range
Kitchen Ranges Logo
312 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
