Question about Little Giant Pool Cover Pump Water Wizard 25ft Cord 1200 Gph 5 Msp 25
How to Replace Little Giant Water Wizard Utility Pump Power Cord
Hi, it looks like the power cord on my pool cover pump ripped and is shorting just at the place where the housing and cable touch on the outside. No room to do a repair and I can not figure out how to open the unit to replace or cut and reconnect the power cord. Can this pump be opened for that?
Thanks
The above advice is pretty generic. The issue with repairing the cord problem is not quite as simple in a real world scenario. Good luck sliding that impeller off the shaft without breaking it. There's really no need for the set screw, considering how binded those impellers are to those little giant water wizard shafts! Without removing the impeller, how are ya gonna separate the housings? These Little Giants like to have cord issues where it leaves the housing...especially if they've been carried by the cord. It's a hard fix, without breaking the impeller. If none of the wires have severed, then the best solution, unless your impeller happens to not be binded like most will be, is to use 2 different diameters of heat shrink tubing (probably 1/2"
Posted on Apr 02, 2011
  • 990 Answers
Yes, If it goes together it will come apart. If it is the one I'm thinking of if you take the base apart there will be through bolts that run through the whole pump, remove these I want to think there are some that are short and these hold the base to the motor but they may be behind the impeller. Be warey as I'm not sure. But once the through bolts are out you should be able to carefully remove the top. Some have very frail gaskets here so be gentel. Once you have the top free there will be a compression nut holding the cord before pulling cord through use a light sand paper to clean the cord so the part you pull through will be fresh enough to seal. Don't lube the cord this will keep it from sealing. Pull it hrough and make your repair and put it back together the way it came apart. Use a sharpie to mark the top and housing as you take it apart. When finished loop some cord through pump handel and tie it off so this takes the weight in the future to keep from having the same problem again. good luck
Posted on Aug 25, 2009
Trips ground fault
clogged impeller take bottom off if impeller is clean bad pump motor need new one or short in cord
Mar 21, 2014 | Little Giant 1800 GPH Cover Pump 115V...
Little giant pool pump cover will not work
auto switch is defective? a simple easy replacement can be sourced from any pool supply co
Jan 18, 2014 | Little Giant Pool Cover Pump Water Wizard...
My Little giant wgp-65-pw has tripped my gfi repeatedly. any idea why? No shorts in the cord are apparent
if a pump connected to a gfci outlet trips , then the gfci has detected a high resistance "shortage" inside pump and has disconnected power , this "shortage" can be nearly in detectable from human standards(shock) , but gfci picks it up
most likely pump seal has failed and water has gotten inside pump !! it only takes one drop to do this !!
Dec 24, 2012 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
How to replace power cord on little giant pump
You have to buy a new cable ,remove the cover plate ,mark the wires before removal. (Colour) etc.Peel back the new wires and fit them exactly the same way as they came off,or get a professional to do the job.
Feb 14, 2012 | Little Giant Submersible Fountain Pump
How do you replace a broken power cord
due to the seals involved and the increadable possibility of leaks happening i dont recomend that you try replacing a power cord on a submurged pump, the risk of shock is just to great for the benefit !! the plug end now that can be replaceed however , contact any licened electrician they can handle that for you.
Jul 17, 2010 | Little Giant 5-MSP Water Wizard...
Little Giant Pool Cover Pump Water Wizard 25ft Cord 1200 Gph 5 Msp 25 Logo
1,318 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
