Question about Brother HL-6050DN Laser Printer
Paper Crinkling I work for a hotel and we have 2 brother printers. After about a month, the paper starts to crinkle. I have contacted brother and they told me that I had to use laser paper, which I changed and now use but the problem persists. Brother has replaced these printers 4 times and they just don't hold up. Any suggestions?
  • 22 Answers
You change your printer fuser unite solve it
Posted on May 29, 2009
Fix Paper crinkling on the left of each page starting about half way down?
Crinkling paper is usually due to either an obstruction in the paper path or a bad fuser, which is the part of the printer that heats the toner so it melts to the page. It is located at the top of this printer. It can be a little challenging to see the fuser on this model, but if you look close you should be able to determine if the fuser is bad. You might also have a bad transfer belt, inspect it closely on the side the has the crinkle.
Feb 28, 2015 | HP Color LaserJet 2600n Printer
How do I stop the paper from crinkling prior to printing in Canon D320
check the whole paper flow. special look out for things in the printer that don't belong there, like a paperclip or screws of paper.
sometimes things fall in a printer and can spot all the fun.
Jan 21, 2015 | Canon Office Equipment & Supplies
Paper crinkling
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | HP LaserJet 3015 All-In-One Printer
Cannot change the rollers due to crinkling papers
You problem is with the fusing assembly in the rear of the machine. This series of Brother are famous for it. If you open the back door you can get access to the fusing compartment. The fusers aren't cheap though, around $100 to 125.00. Cheaper to buy them from Ebay than through a dealer (and I am a dealer) as there are folks that are just taking the machines apart for parting them out. Just make sure you go with a new fuser, not used.
Nov 04, 2009 | Brother HL 5250DN Laser Printer
Only on Quicken to 3210 all-in-one printer. Paper starts to feed then indicates paper jam, wait long enough and paper feeds with crinkle and no print.
I would check the paper path on the printer where it is crinkling the paper. More than likely there is some small piece of paper or something that is causing it. Does it only do this out of quicken? I wouldn't think so if the paper comes out damaged....
Feb 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Lexmark x1240 printer / scanner
I don't have a 1240 printer but we have had this problem. Usually we just align the paper and there is usually a movable piece that keeps the printer snug and aligned. Usually we move it right at the edge of the paper. This usually prevents the paper from crinkling. If this doesn't work I would guess that one of the rollers is not working. But my guess is more of the paper guide that you need to move so that the paper stays aligned when it goes in. Let me know if this helps.
Nov 14, 2008 | Lexmark X1240 All-In-One InkJet Printer
Paper feeder problems
It is easy to remove the tiny piece of paper either by blowing air into printer or you can remove the roller to find where the paper is stuck so that you can find it and remove it .
If you need schematic diagram for your printer to remove the paper let me know .
Thanks for using Fixya .
SAM ANDERSON
Sep 16, 2008 | Epson Stylus CX4200 All-In-One InkJet...
PAPER CRINKLING
First check the paper path for something in the paper path. Staple, paper clip, etc, causing the paper to twist. Reseat the imaging unit and see if the transfer unit is seated properly.
But, What sounds most likely is that the fuser needs to be replaced. The rollers are most likely getting pretty bad inside that unit.
If I recall correctly, it is in the $200 range to replace.
Feb 16, 2008 | Xerox Phaser 6250DP Laser Printer
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Brother HL-6050DN Laser Printer Logo
211 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
