Question about HP Office Equipment & Supplies
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
My HP Deskjet D1320 makes a grinding noise before it prints. It also stalls during this grinding noise, but evenutally the cartridges align and print out the paper. We had a similar problem with a Compag IJ600 printer and it eventually just made the grinding noise and wouldn't print all together so we threw it out and someone gave us this printer. The D1320 worked fine until I replaced the black and color cartridges. Now it makes this grinding noise. Can you tell me how to troubleshoot this and get it fixed?
  • HP Master
  • 511 Answers
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
Canon ic-1320 toner rubs off copies
if toner rubs off then fuser unit is not heating paper to fuse toner to paper. You may notice paper printed on is not hot .
Jul 14, 2016 | Canon imageCLASS D1320 Laser Multifunction...
My printer chew one side of paper laserjet 1320
Is the correct model number: HP Deskjet D1320 Printer ? Was printer working properly at one point? May be resulting from failure to fully clear a paper jam:
Paper jam
To clear a paper jam
1. Remove the paper from the paper tray.
2. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
3. Turn off the printer.
4. Remove the rear access door. Press the handle to the right, and then pull out the door.
5. Remove the paper jam from the back of the printer, and then replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Caution Remove the paper jam carefully as it is possible to damage the printer when removing paper from the front.
7. Reload paper in the paper tray.
8. Turn on the printer.
9. Reprint the document
if this does not help I would suggest installing a new driver from: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ca&docname=c00211293&product=1839853&
Trust this is helpful. :)
Dec 08, 2010 | HP LaserJet 1320 Printer
Hp deskjet d1320 yellow light keeps blinking
Thank you for suggesting that the cartridge might be bad. I almost got rid of my deskjet D1320 because it was blinking continuously and I could not figure out why. I tried everything from new driver to looking for a paper jam and nothing worked until I tried your suggestion. I tried each of the cartridge separately to find out that the black cartridge was making the light blink but not the color on. I replaced the black cartridge and the printer is fine now
Oct 25, 2010 | HP DeskJet 1220c InkJet Printer
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Oct 09, 2009 | HP LaserJet 1320 Printer
MY PRINTER WON'T PRINT
Try to check the user manual to troubleshoot what errors/issues that caused the printer to stop working
Jul 08, 2009 | Office Equipment & Supplies
HP Deskjet printing noisly with a cracking sound
9 times out of 10 what you have is 2 cogs that are offset - ie they are grinding their teeth and you can fix it but is a deskjet printer really worth all the hassle...
Jun 20, 2008 | HP DeskJet 810c InkJet Printer
Hp 1320
I want the software of laser jet 1320 printer
May 19, 2008 | HP LaserJet 1320 Printer
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Deskjet 895Cse is "sucking" paper in and stalling
Sounds like the printer is getting a bad command from the driver. Try upgrading your driver. Also it may be a bad document. Copy and Paster your text into a new document to see if it clears the corruption.
Sep 28, 2007 | HP DeskJet 895cse InkJet Printer
1,818 people viewed this question
Seeker5211
Seeker5211
