Question about Concept (CC752L) Car Audio Amplifier
Concept cc752l how many watts
How many watts is the Concept CC752L Car Amp? i need to know and cant find it anywhere would it be powerfull enough to hit a 12 inch kicker L7?
    Problem Solver:
  • 6 Answers
A easy way to tell how many watts an amp has is to look at the fuses on the amp itself eg. if it has one 10 amp fuse its probably a 100 watt amp, or say a 30 amp fuse would be around 300 watts. Most amps have more than one, so just add up the fuses and times it by 100.
Posted on May 29, 2009
How much rms dose amp have?
Concept CC-2502 2002 900 watts max Rms
Feb 24, 2011 | Concept CC-2502 Car Audio Amplifier
I wont to know if i can run 2 2410s concept amps bridged and how to do it thank you .they can run at 2410 watts at 1ohm or 1150watts at 2ohm .iam wanting to hook them up on a rdaudio v2 15 that is duel...
If you only have one of those speakers the lowest load you could present to an amp would be 2 ohms. So 1 ohm is out of the question. I would advise you to get another speaker and use 1 amp per speaker bridged mono @ 2 ohms. Connecting the outputs of power amps together is not advisable.
Dec 18, 2009 | Concept CD-2410 Car Audio Amplifier
How many watts dose a concept cc-752L amp have ?
4 Ohm Stereo Power (RMS): 75W X 2
4 Ohm Bridged Power (RMS): 250W X 1
2 Ohm Stereo Power (RMS): 125W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Sep 26, 2009 | Concept (CC752L) Car Audio Amplifier
What speakers
Hello enot99,
The CC-2502 is a bridgeable 2-channel amp. If you want to drive normal speakers in stereo, the best would be a good set of components with separate woofers, tweeters, and crossovers. They are available in many sizes from most car audio manufacturers. I'd begin by finding out what speakers fit the location where you intend to mount them. Then I'd browse the speaker selections in that size at www.crutchfield.com. You can also use the "outfit my car" feature to browse only the products that fit. Then select a pair that has a power range and impedance to match the amp: 250 watts RMS at 4ohms or 450 watts RMS at 2ohms.
If you want to use the amp in bridged mono mode to drive a subwoofer, again Crutchfield has a large selection of subs and some enclosures already fitted with subs (loaded). The amp claims 850 watts RMS into 4ohms bridged, so look for a sub that has a power handling rating of at least 850 watts and it needs to be 4ohms.
Hope this helps.
Aug 02, 2009 | Concept CC-2502 Car Audio Amplifier
I have a 2400 watt concept amplifier and if i turn it up too much it sends a real loud hum throught my subs. I really want to get it fixed because this has ben a very good am to me. If i need this repaired...
yes that cause from yhe gain is too high on the amp and you getting a ground loop traveling thru the rca signal
once the gain is high you will hear it make adjust on amp
Mar 29, 2009 | Concept CC-2502 Car Audio Amplifier
Speaker load
seeing that is a a/b class concept i know it will do 1ohm but if dont have good battery power stay at 2ohms with it and it will do fine
Dec 28, 2007 | Concept 460 Watt 4X60, 1X200 5-Channel...
Concept (CC752L) Car Audio Amplifier Logo
432 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
