Question about Acer Extensa 4620 Notebook
Keyboard not working
The keyboard was poured by a hot coffee, now it is no working
  • 73 Answers
Wuw sorry but you will need to replace the keyboard. visit your nearest vendor for replacement
Posted on May 29, 2009
    President:
  • Acer Master
  • 1,314 Answers
Your keyboard needs to be replaced.
Coffee dripping out of spouts instead of pouring.
You have not included the make and model of the coffee maker.
Oct 15, 2014 | Coffee Makers & Espresso Machines
Hot water will not come down thru coffee
Your pour over coffee brewer has a reservoir that holds more than a pot of water. First thing you need to do is turn off the machine. Then put the empty coffee pot on the burner. Then take another container and fill it with fresh cold water and pour it slowly into the coffee maker until it starts to come out into the coffee pot. Stop pouring in water.
Now turn the machine on and let it heat up. Now you can brew normally. The reservoir has to be filled before you turn it on or you will end up eventually burning up the heating element.
Dec 31, 2013 | Bunn A10 Coffee Maker
How does the drip method work to produce a cup of coffee?
Hot water is poured over ground coffee, which is contained within a filter. The water then steeps and drips through, producing coffee. This method of making coffee is also referred to as filtered coffee.
Feb 07, 2013 | Wine & Spirits
We poured the amount of water needed to make the amount of coffee desired but 30 minutes later no coffee was made. Does the bottom "warmer" button need to be on or does the maker just need to be...
The tank inside holds about 2 and a hlalf pots of water. Once the tank is full, whatever you pour in will come out. The unit has to be plugged in to make coffee. Leave a pot under the brew funnel and pour a pot of water in. If nothing comes out within a minute, pour another pot of water in. Still if nothing comes out do it again. This time for sure water will come out. It will take avout 10 minutes to get hot enough the first time it is full to make coffee. If you have a thermometer, the water should be about 190 degrees F to make coffee correctly.
Oct 28, 2010 | Bunn VPR Coffee Maker
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Can I convert this unit (38700.009) to a pour through? If so, will the hot water spigot not work?
Can the unit be converted to a pour over.
On the top of the unit, does it have a solid sheet metal cover or one with a filler plate and screw.
If solid cover. converting the unit to pour over will cost more than the unit is worth.
If you need a pour over unit, Contact your local sales and service dealer, see if they will do a trade in on this unit for a new pour over unit.
On pour over units, NO hot water tap.
Jan 07, 2010 | Bunn 38700.0009 Coffee Maker
Hi! I got a new Bunn VPR last week but did not run water through it because I was waiting for our maintenance guy to install a GTRI outlet for it. When he installed the outlet on Saturday he plugged in...
It sounds as though the thermal cutout has been put to the test and it didn't pass. I would advise you to try to get the company that the repairman works for to replace the entire machine, after all it is brand new and changing parts at this venue could void the warantee.
Sep 22, 2009 | Bunn VPR Coffee Maker
The coffee maker doesn't work - all the lights, timer, on/off switch, etc., seem to be working, but the water doesn't pour through the grounds to make the coffee
Does it make steam or can you hear the water boiling? Try and pour 4 cups of vinegar or lime away in it if it is clogged or plugged up from lme or mineral deposits, if it not getting hot( you can tell very easily by seeing if the plate the pot sits on is getting hot) then the thermocouple or heating element is shot.
Jan 26, 2009 | Krups 888 Centro
The carafe dribbles coffee when pouring.
This has been a problem with many carafes. I tried something I saw on a home show once, and it works, but... it may seem weird and undesirable. Unless you pour just the tiniest stream, the liquid wants to stay with the pot, you see. It will be attracted along the spout back down the pot, causing the dribble.
Put just a tiniest smear of shortening or oil on the pouring lip, and the problem will instantly disappear.
You've already guessed the undesirable part of this, right? Yep. It doesn't last for long because the hot water cuts through the film after a few pours. And, who wants Crisco in their coffee?
I didn't notice anything different with my coffee when I tried it. Probably not enough grease to make that much difference.
But the "back-drip" ended pronto.
Joe Java Lover
Jan 17, 2009 | Hamilton Beach Stay or Go 45238 10-Cup...
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
Acer Extensa 4620 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
