Question about ViewSonic G790 19" CRT Monitor
Shrinked screen width!
My ViewSonic G790 VCDTS21385-1 E monitor's horrizontal width got shrinked at once. it seemd like causing dry joints and really there were lots. So I resolder entire horrizontal defflection section but the problem is not cured.
4 Suggested Answers
  • 1601 Answers
SOURCE: have no sound
your monitor has no speakers for sound.
Here are the specs:
Posted on Dec 01, 2007
SOURCE: Monitor Height Shrinked and unadjustable.
that is my problem right now,,,just get your monitor and threw it use its a junk...
Posted on Feb 13, 2008
  • 981 Answers
SOURCE: Horizontal widh shrinked
Huh, it sounds like the monitor's horizontal deflection amp (a big transistor) failed. It is not so if you can feed it a good signal and get a wider picture.
You would replace that thing with a transistor with a similar drive profile (i.e. not a FET), if you practice the right safety; better to use a service tech to do it unless you were trained in it. Alternately, you can try freezing your monitor (wrap it to keep out condensation! I only mention this because it's freezing out, where I am....) and see if this helps the transistor recover; it's not that sage or safe though, because of the condensation/electricity hazard and unlikely event that you will ground a work bench surface to do this test!
Be safe and consider using lower-power-consumption flat screens in warm weather.
Posted on Feb 23, 2008
  • 13 Answers
SOURCE: the screen has shrinked in horizontally and 2 vertical lines
Try repairing your monitors cable.
Posted on Dec 31, 2009
0 characters
1 Points
Video shrink to half the size of montor
you can solved your problem by your self but i am not sure it will work 100%.,1st UNPLUG power cable for safety! just open your monitor back cover via crew driver., now you should see some adjustable plastic scree on board plug your monitor with power and witch pc. now try to adjust plastic crew one by one. you will find the screen re-sizer crew. hope it will work. if this is now work then you should visit a good local engineer.
Dec 11, 2013 | Computer Monitors
The shrinked screen with two white vertical line in the middle
B+ line going hi.
probably bad capacitor on hot's collector.
could also be leaky dual diode.
if non of above, look for swollen cap on main board.
Jul 12, 2008 | LG Studioworks 700S 17" CRT Monitor
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
G790 HV xformer wanted.
yes, purchase it from company or change the part with some other parts
Dec 14, 2007 | ViewSonic G790 19" CRT Monitor
Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
Oct 15, 2007 | ViewSonic VG2030wm LCD Monitor
Shrinked monitor of a personal computer
Have you try it on another pc ,if not try it and if this does not work, look if your monitor is not near a source of electromagnetic waves (like a speaker)remove this source,if this also does not work there is definitely a hardware problem. Which the cause maybe in the deflection block or any akin circuits
Jul 04, 2007 | Likom Futura LD5 15.1" CRT Monitor
Dec 05, 2006 | Likom Futura LD5 15.1" CRT Monitor
56v-Screen shrinked horizontly
You need to service your monitor. Give it to an authorized service center.
Dec 15, 2006 | SAMTRON 55V 15" CRT Monitor
ViewSonic G790 19" CRT Monitor Logo
Top ViewSonic Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer Monitor Expert? Answer questions, earn points and help others
