Question about Kenwood Audio Players & Recorders
How do i connect them
How do i connect a kenwood amp to a graphic eqoalizer home hifi seprates i have a kenwood k550d amp & a kenwood ge420 equalizer,how do i connect them?
I connected the red & white audio leads to the line out sockets on the equalizer and connected them to the tape rec sockets on the amp..
Posted on May 30, 2009
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
I have a kenwood vr506 amp . the remote no longer works.i have bought a one for all universal remote and need the code for the kenwood amp.
setup codes for cd players - HiFi Remote
www.hifi-remote.com/hag/setup_codes.htm
Sep 15, 1999 - If you are unsure whether your universal remote uses 3 digit or 4 digit ... SETUP CODES FOR AMPLIFIERS ... 0078 JVC 0331 Kenwood 0356 Linn 0269 Luxman 0165 Magnavox 0269 ... GE 0240 LiteTouch 0084 Lutron 0318, 0597 One For All 0167 .... 0048 may require TV code 0093 for volume and mute.
vcr set up codes - HiFi Remote
Feb 16, 2015 | One For All Televison & Video
Connect tv to hifi speakers
It doesn't lokk like your TV has an analog out for your Kenwood system. It might have an optical out but unless the Kenwood has optical in then you'll need to upgrade to a Home theater system with HDMI.
Feb 03, 2015 | Samsung Televison & Video
Need the 4 digit code for a kenwood vr-405 reciever with my kenwood rc-ro509 remote..stop working?
Here are some remote codes for Kenwood Receivers.
The codes are as follows: One of them should work
0027, 0077, 0313, 0186, 0314, 0356
Here is a link to a web site that has universal codes for remotes.
http://www.hifi-remote.com/ofa/codes-amp.shtml#amp
Hope this helps,
Best Regards,
Mark
Jan 27, 2011 | Kenwood VR-405 Receiver
I have a Kenwood mini hifi system XD-A700 i cannot open the CD player drawer to play cds.I dont have an instruction manual.
You can download the manual at
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/xd951.pdf
Aug 29, 2010 | Kenwood XD-A700 Shelf System
How to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Jul 04, 2010 | Kenwood Audio Players & Recorders
Hi I would like to know how to wire up a kam keq 15 dual band graphic equalizer to my home hifi thanks
Either run the main ouptut for your amp to the input of the eq and output of the eq to the main input of your amp OR use one of your tape monitors on your amp. Record on your amp goes to eq input and play on your amp goes to eq output. Hope this helps you.
Jul 29, 2009 | Audio Players & Recorders
RIGHT HAND SPEAKER, DISTORTION.
First switch the speakers over to make certain it is not the amp that is the problem.
If the speaker is still playing up on the other channel, then I would look around at a new set of speakers. They can be any that you like the look of as long as they have a power ratting at 40 watts or above each. The amp says it can take 6 to 16 ohm speakers. I would go for 8 ohms as they are more common.
Jul 03, 2017 | Kenwood NV-600 CD Shelf System
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
Connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
May 28, 2008 | Audio Players & Recorders
578 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
