Question about Philips Portable DVD Player PET-805
My player is not reading DVDS
My DVD player is a Philips portable player and when i play the DVD's that i burned on nero is gives a comand NON READABLE DISC. i tried almost all the burners but the result is nil. has it got something to do with +DRW or -DRW ?
  • 4 Answers
SOURCE: philips DVP642 DVD Player "No disc" problem
if its still under warranty, do that.
if it's not, try taking it back to the store and asking for a replacement. don't let the floor salesman tell you no. insist on speaking to the manager. my strategy is to: "be polite, appear slightly stupid, and dont take no for an answer" it works 80-90% of the time.
if you cant get anywhere (or dont want to try that route), then you have nothing to lose. open the case and try to clean the mechanism and lens
two screws on either side of the unit, and i think another 4 screws on the back side. this will allow you to pull the top cover off the unit.
clean the mechanism, and clean the lens. you can buy cleaner if you want, but i just use a soft cloth and some "no-streak" type window/glass cleaner (windex)
clean your disks as well. this DVD player seems to be sensitive to scuffs and dust more than some other players. you just have to be persistent.
or you could buy another DVD player. at $60, its really a pretty good deal anyhow.
good luck
Posted on Mar 09, 2008
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Posted on Aug 28, 2008
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
SOURCE: my philips dcp850 portable dvd play battery won't
have you had this problem fixed?
Posted on Aug 09, 2010
SOURCE: Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Posted on Jan 23, 2011
0 characters
1 Points
Problem with Mintek MDP-1810 Portable DVD Player that will play movie DVDs but not computer burned video DVD
The problem I think is with the burner on your pc. Try re burning on another program like Nero and pay attention to the options. It will ask you if you wish to play disc in all types of players.
Dec 25, 2013 | Mintek MDP-1810 Portable DVD Player
Hello! I want to make my Philips DVP3350V/01 player so it can take Region 1 DVDs. How do I do?
First you have to download linked file called "LG36868.IMG"
1. Then you have to burn this file to a blank CD
(The file "LG36868.IMG" is NOT an image file!. Just use
Nero or any of your CD burning programs to write this
file on a CD.
2. After burning, insert the CD into the DVD player and press play
3. Then the region management menu will be shown.
4. Input "0" to make it multi-region and then press the "pause" key by
Remote Control.
Enjoy, your DVD is region free!
Please dont forget to vote if you liked my answer
Feb 09, 2011 | Philips DVD & Blu-Ray Players
Philips HTS3565D dvd player, recent Paramount DVDs (Star Trek and Transformers 2) freeze during the Paramount DVD introduction at the exact same spot: as the stars are flying in toward the camera's view....
I have the same problem, though I don't recall which exact movies. They were all from Blockbuster. Sometimes they start to play and then halt at the end of track 1 and sometimes don't even make it tot he menu. The same movie will play on our portable dvd player. A Philips rep told me about 6 weeks ago it was a problem with a new security feature on some movies and to watch the website for a possible firmware upgrade to fix it. Now you can't even talk to someone at Philips so I don't know what to think. The "live chat" folks just want to tell you to take it to a repair shop - not much help there.
Mar 04, 2010 | Philips DVP5140 DVD Player
Multi region dvd not playing region 1
Two issues: if it isn't playing Region 1 discs, then that particular player was designed for use outiside of the US. It is illegal to change the region code, so I would call Philips and get a replacement. But, if you want, there are YouTube videos that show you how to unlock the code - it can only be used 3 times and then it locks up permanently.
Second issue: if it won't play NTSC DVD's, go into the menu and take it off of PAL - if it is stuck on PAL, then that player was definitely designed for outside the US. Call Philips and get a replacement.
The PET940 is the general model number - afterwards is a country code - if it doesn't say PET940/17 or PET940/37, then it is a non-US player.
-Tha Mp3 Doctor
Jan 01, 2009 | Philips DVD & Blu-Ray Players
the disk will not spin at all. the screen says no disk. this device is knew . what will cause this
Oct 08, 2008 | Philips PET702 Portable DVD Player
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick to author your dvds and use imgburn to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Sep 30, 2008 | Philips DVP5140 DVD Player
Cannot read disc
Had the same type of problem; I called Magnavox on this one. These DVD players aren't "guaranteed" to be able to read discs that were "burned"/homemade. They're only "guaranteed" to play commerically produced DVDs. If you're trying to play something that you made it probably isn't going to work.
Jul 31, 2008 | Philips Magnavox MPD845
Player does not read dvd disc
You already clean the laser lens.
Jul 01, 2008 | Polaroid DVD & Blu-Ray Players
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
DVD & Blu-Ray Players Logo
24 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
