Chip 48 is fried and i need to replace it preferably with another kind of chip for which i need technical advice on which one to use
My fujitsu got heated,sparked and burnt a chip labelled 48 close to the sata hard disk connection on the board. I want to replace it but want technical advice on what other chip to use other than that same chip.thank you
    Novelist:
  • 166 Answers
The IC which got burnt was for SMPS regulator. And this is necessary for constant DC supply to all components on your other board. So go on the shop and ask for specified regulator IC and also read all datasheets or documentation before replacing it.
Rate this solution if it was helpful to you.
With Regards,
Shyny
Posted on May 29, 2009
Security won't let the car start
General advice:
Immo condition:
Dead key battery (may need to press button(s) on the key to get the chip activated
Key sincro (ceck owners manual )
Key chip fried/key reprogramming.
Bad Antenna ring/plug (around the ignition barell).
Use second key.
Try disconecting the battery for some minutes.
Try emergency procedure (if apply,owners manual)
Tricky bussines.
Hope u deal it,let others know.
Oct 27, 2013 | 2002 Cadillac Deville
Tip
Reset Bose LifeStyle 48 VChip Password
Bypass or Reset Bose LifeStyle 48 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 48 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Bose LifeStyle 48 Video Mode
on May 02, 2010 | Bose Lifestyle 48 System
Is there a stock harley 16x5 solid disc rear wheel that will fit my 2011 sporty 48?
Hi Skinillustra, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Mar 13, 2013 | Harley Davidson Motorcycles
How many lamps are in fujitsu 5750c scanner? how can i replace them?
Hi Albert,
There are two CCD lamps inside Fujitsu fi-5750c Duplex scanner.One is ADF Front and the other is ADF Back.To replace them, you may need the help of Fujitsu certified technician, for the procedure requires technical expertise.
Thanks & regards,
ScanCare
Nov 08, 2011 | Fujitsu fi-5750C Flatbed Scanner
Re; HP 6735b Laptop Bios and admin are password protected by previous owner. I understand this can be corrected by replacing the CMOS chip on the motherboard. I am fairly technical but need advice on who...
Hi george.
I'm afraid you will have to get in touch with HP about this problem. The reason being is that yes you can de-solder the BIOS chip but this is very hard to do with it being on a laptop motherboard. You will need a very steady hand and also a heat gun to melt all the solder points on the chip to remove it, then you have to get the new chip in place properly which again is not easy, even for a tech like me!! To be honest with you I personally wouldn't bother trying to do this because it's that hard to do. If you can prove ownership of the laptop then HP will give you the master reset code to wipe the password from the BIOS.
I'm sorry but this is the best advice I can give you.
Kind regards.
Aug 11, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
Looking for Service manual. Can anyone direct me to the right location?
Service Manuals are only available to approved Service outlets so therefore can be quite difficult to aquire on commercial high end scanning products. You could Email Vrs.king@ntlworld.com for more information.
Dec 14, 2010 | Fujitsu fi-5900C Pass-Through Scanner
Chip very hot on motherboard and laptop will not boot.
well i had a amd chip that would get really hot and it would make the computer not boot up at all so i replaced it and it fixed the problem i was told it was about to go out so maybe this advice will help u good luck
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
BIOS PASSWORD
the pins you are looking for are usually the same ones they are jumper pins JP1 and JP2 the pins usually have a caption near it CLS CMOS . BUT this is a bios issue , the information will most likely not be reset by doing a CMOS reset i know for this issue with the IBM thinkpads you have to have the chipset replaced , and im sure it will probably be the same for a F-S. you can try the other approach but im not sure what will result from it
Apr 12, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Replaced IC chips and fried something
1)WHICH chips?? 2)Which resistors? (locations) 3)It is worth it. 4)Possible,but usually not needed.
Sep 19, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
