Question about Kenmore 24032\24036 Top Load Washer
Kenmore Elite Washer 110.24992300 spin problems
Kenmore Elite 110.24992300 : My Kenmore Top Loader won't spin sometimes. It does everything else seemingly fine except, intermittently, it won't spin. If I fill the tup up again and run the wash or rinse cycle again it usually will start spinning again during the spin cycle. I haven't figured out what triggers it to stop spinning. Also, it seems not to spin fast enough b/c after the cycle the clothes are too wet. Sometimes I let the load sit and then spin it an extra time to hopefully extract more water. Talk about waste. Help. Thanks in advance.
  • 15,935 Answers
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
I have a top loader kenmore elite washer t won't finish a load without rocking
You may have an item between tubs:
Service Manual
If this ain't yer model look around the blog for yours. American made stuff is what I do. Cheers
Jun 21, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Kenmore Front Loader Washer Doesn't Drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
Spin out
kenmore elite washer 11024992300 top loader will not spin or empty.
Jan 19, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Clothes come out super wet
Drive motor failure, CCU or Motor control failure. To ceck this look at your owners manual and from then test the parts with a multi meter. To keep from spending money you can unplug your machine for 15 to 30 minutes, plug it back in and sometimes that will clear the code and everything will work just fine. Also some parts are covered under the 5 year warranty so make sure about that also
Apr 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
750 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
