Noise coming when i switch on the copier gear breaking noise is coming. this happend when i wrongly inserted the toner.
  • nazaha May 31, 2009
    Yes i have done this, even without the toner the noise comes.
  • 1,326 Answers
I would say remover the toner agian and let the copier go into it's warm up and make a copy then reinstall the toner back in
Posted on May 31, 2009
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
ADDED TONER STILL ERROR ADD TONER
You can drop the toner cover and cheat the door sensor and watch the toner bottle to see if it spins or not. If it doesnt spin- the end result is not good especially if you have a grinding noise. or just the toner bottle not spinning and it asks to replace toner. The back of the machine will have to come off. You will have to remove all the covers and finisher off the front. Then get to the toner add mechanism and take it out. The one gear will probably be sideways because- if the customer put the toner in wrong or maybe the wrong toner in- it will bind and bend that back shaft. thereby screwing it up. It takes a lot of time and parts. First thing you need to do though- is to see if the bottle is spinning or not
Jul 25, 2012 | Minolta bizhub 250 Black and White Copier
Hi There, Our copier is making a horrible
Have you resently added toner? If so, try to reinstall the toner. Odds are that you will need the fuser rachet driver gear. Also, on the toner cartride, did you remove the cover for the waste toner??? You may have a packed waste toner feed screw... Good Luck
Feb 02, 2010 | Sharp AL 1631 Copier
My HP m3035 printer is making noise in the toner cartridge compartment on the right grinding sounds. I changed the Toner, still amking the noise any ideas?
Open the rear door. Power on the printer. Watch and listen as the fuser rotates. Does the noise occur when the fuser rotates? if yes - replace it. If you still think it's coming from the toner, remove the toner, close the toner door. When the motors start turning the noise should be gone. Insert the toner and listen again
Jan 28, 2010 | HP LaserJet M3035 MFP Printer
The toner light of HL 2140 will not go off. even if i turn the printer on/ off and wait for a few minutes. i've also move the green thing back and forth a hundred times and still the same. Please help!
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.
Thier is a counting gear on the left side and on new or replacement cartarages it is in the 11 oclock postion when it is new. When the toner is all used it moves to the 3 oclock postion. What you need to do if you refilled the toner from a refill kit is to manually move the gear.
I believe thier is two ways to do this one buy a reset gear tool.
The other way that I do is to remove the three screws carefully that holds all the gears in place. Dont worry as it is just the cover and you can not really break the cartarage unless you strip the screws.
Once opened manually using your hand push firmly on the counting gear until you move it back to the 11 oclock postion. Then carefully reassemble the cover.
Once you place the cartrage back in the light will go off on its own and the toner counter will be reset.
3 don'ts
Do not try to only move the counter you may get a few pages but this is bad for the printer
Do not leave any toner in the cartrage when refilling as this contaminates the toner and really shortens the refill life, try to get all the toner out as possible before refill.
Do not keep reshaking the cartrage and place it back in the printer, everytime you insert the cartarage the it can snag or be inserted a tiny bit wrong and break the gears in the printer. Do so in emergencys only, the rest of the time just refill the toner. $10 with delivery on ebay
Sep 05, 2009 | Brother HL 2140 Laser Printer
Brother 2140 toner light keep flashing and i just replace it with new toner
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.(Or if the replacement has a missing or broken or miss postioned counting gear.)
3 don'ts
Do not try to only move the counter without refill you may get a few pages but this is bad for the printer
Jul 09, 2009 | Brother HL 2140 Laser Printer
When printing, grinding noise occurs
Try a different toner cartridge. If you still get the noise, it will probably be the fuser. They have gears and bearings that sometimes break.
Mar 17, 2009 | HP LaserJet 2200D Printer
Samsung 3160fn all in one printer. making loud clicking noise when printing
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
May 05, 2008 | Samsung CLP 300 Laser Printer
Loud clicking noise
Power the machine on with drum and toner removed, check for noise....
It will be either the Fuser, Toner or the drum.
If it is non gen. or refill toner, fault found.
The drum is a normal consumable that you change every 3 to 4 toner cartridges, so if any of you have used more than 4 toners and havent changed the drum, I'd say that we have found your problem.
......now to the hangers on .....
Fuser, thats the hot bit at the back, these have a gear that cracks because the whole fuser assemble is old, brittle and stiff, you can pull it all apart and change the gear and be off, but soon it will more than likely break again, I know cause if I do that as the fix they come back within 6mnts.
Replace fuser, or have it replaced
f9d929d.jpg LINK to P/n and price
the gear that breaks/cracks
9b32a46.jpg LINK to gear info
Fuser is a HiVolt, HiTemp part. Caution!!!!
Nov 16, 2007 | Brother HL 1440 Laser Printer
46 people viewed this question
k24674
jasbo
jasbo
