No power to the blue wire to module, coil power in is ok,dont know which fuse is for ignition but all fuses that are powered are good. tryed another known good computor still the same problem.
There are two blue wires at the module one is out put to the tach the other is coming in from the coil if this wire does not have 12v coming in with the key on check for 12v on both sides of the coil with the key on you should have 12v on both side if you dont swap outt the coil ( but normally in this case when you dont have spark your crank sensor is bad )
