Question about Jet 3 Ultra Power Chair
I have the jet 3 power chair. It was turned on and will not turn off. Just makes a beeping noise. Any idea what this could be and how I fix it?
  • 37 Answers
Try a few things. First, push the reset button located on the bottom of chair right next to the foot rest. If that doesnt work, take the back outer covering of the chair and disconenct the battery connector and wait a few minutes then reconnect it. Also check the 50 amp fuse located behing the foot rest, take the pin off the bottom of the foot rest and expose the batteris and you will see the fuse.
Posted on Jun 23, 2009
Jet 3 Ultra kicking error code 3 red, 4 yellow, 1 green.
check connections to controller, may have damage.
Jan 15, 2016 | Jet 3 Ultra Power Chair
Why isn't chair charging?
1. Make sure that your chair is turned on.
2. Make sure that the brake release levers are in the drive position. See owner's manual.
3. Make sure that your chair is charged. 4. Make sure that your chair is not plugged into the wall.
Aug 04, 2015 | Jet 3 Ultra Power Chair
When i turn chair on lights on controller blink and also beeps loud constantly, what do i do, it wont move either
The pattern of lights and beeps should tell you what the problem is. The chart is in the manual. You can download one if needed.
Mar 16, 2014 | Jet 3 Ultra Power Chair
How do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
Sep 04, 2012 | Jet 7 Portable Power Chair
All lights are blinking rapidly when trying to turn on and nothing works Thank you
DBowers check to make sure that your chair's motors are not in freewheel. If they are not check to make sure the charger is not still plugged in. If both of those are correct the chair might be in sleep mode. Check your owners manual to see if they tell you how to get it out of sleep mode. I think that on the Jet you turn on the chair and within 10 seconds push the joystick forward and hold it there until you hear a beep then immediately push it to the rear until you hear another beep then immediately release the joystick to the center. If you were in sleep mode the joystick should operate normally. Now I have had to try to get it out of sleep a couple of times until it returns to normal. Hope this helps
Sep 20, 2010 | Jet 3 Ultra Power Chair
I have a power chair it is a jet 3 ,the lights flash , i know there is a code to reset it , so can you help me. i have had it repaired before and they just reset it but i need to now how,
Hi. Different numbers of LED's flashing mean different faults.
Your machine can be in "lock " mode.
To unlock it, turn the machine on.
Move the joystick full forward until it beeps.
Then move the joystick full reverse until it beeps.
The machine should then work normally.
If you still have flashing LED's, count the flashes between the pauses, and let me know.
Good luck. Neil.
Jul 05, 2010 | Jet 3 Ultra Power Chair
The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
May 12, 2010 | Jet 3 Ultra Power Chair
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Sep 06, 2009 | Jet 3 Ultra Power Chair
All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Apr 28, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
142 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
