Question about Lowrance Hs Ws 50dbk Transom Mount Transducerdesc: 36 Degree 50 Khz
Lorance x25 and x48 configuration, same transducer imput to unit?
Can I us my old transom mounted transducer used on a older X25 on a newer x48 unit. That is, will the transducer plug fit the x48?
  • 285 Answers
My boat fuel gauge flickers very rapidly from empty to full, is that the sender that's haywire?
Posted on Aug 28, 2009
How to reset the Kenwood vr-716
Unplug power cord from the wall outlet, then plug it back IN WHILE HOLDING DOWN THE POWER KEY = only for U.s.a and Canada
For other Countries With the power cord plugged in, turn the POWER key
OFF. Then, while holding down the ON/STANDBY
key, press POWER.
Memory back up function
Please note that the following items will be deleted from the unit's
memory if the power cord is disconnected from the AC outlet for
approximately 3 days.
• Power mode. • Distance setting.
• Input selector settings. • Input mode setting.
• Picture output. • Midnight mode setting.
• Speaker ON/OFF. • PRO LOGIC II mode setting.
• Volume level. • Broadcast band.
• BASS, TREBLE, INPUT level. • Frequency setting.
• Dimmer level. • Preset stations.
• MD/TAPE settings. • Tuning mode.
• Listen mode setting. • CINEMA EQ ON/OFF.
• Speaker settings. • LOUDNESS ON/OFF.
• SW RE-MIX ON/OFF.
Cautions
MODEL PARTS # REMOTE CONTROL # DESTINATION
VR-705-SA A70-1612-05 RC-R0626 K1P1
VR-707A A70-1617-05 RC-R0824 K2P2
VR-716A A70-1617-05 RC-R0824 K4P4
REMOTE CONTROL vs MODEL
DIFFERENT POINT
ACCESSORIES / CAUTIONS
Model Service Manual Surround Display Sub
VR-705 B51-5840-00 X09-6740-10 -
VR-705-SA - X09-6740-11 X25-6600-10
VR-707 B51-5840-00 X09-6750-12 X25-6520-12
VR-707A - X09-6750-14 X25-6610-10
VR-716 B51-5840-00 X09-6750-11 -
VR-716A - X09-6750-13 X25-6600-10
Note:
A different information will be available from this service manual. Pls refer to original service manual(B51-5840-00), too
Nov 13, 2016 | Kenwood Audio Players & Recorders
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
I have a Humminbird 565 that is about 3 years old and the end of the transducer has opened up and the sealant has all leaked out. I also have and older one that is doing the same thing. What's up with...
I have no idea, I use these same ones and havve several mounted and they are used both in summer and winter, never had one leak. I also looked up these and did not see where there were any issues with this problem. I suggest you call Humminbird and talk to them, they are usually very helpful.
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Mar 04, 2011 | Humminbird Fishfinder 565 With Transom...
How far do i pull out the tab on the x25 canon cartridge
Hi!!
Pull it all the way!It will end as soon as its done!!!
Cheers!!!
Jan 22, 2011 | Canon X25 Toner Cartridge for imageCLASS...
My Matrix X25 used to function correctly but it gives me now erratic depth readings and at times get paralyzed on a 7 or 8 meters reading? The auto test indicates that the sounder is OK I checked the...
My unit, a 365i combo, uses the same transducer, I experienced the exact same problem last week, my unit is still under warranty, I sent the unit for repair and just got confirmation that my transducer went bad. The bad news is that the transducer is back order and has been for many weeks, this is an indication of probably a weak design. I have read similar reports on other forums.
Good luck
Sep 01, 2010 | Humminbird XNT Transducers XNT 9 20 T ...
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Jun 22, 2009 | Raymarine Boating
Ho to refill Cannon Imageclass X25 toner?
You're only asking for problems trying to do it yourself. It' extremely messy, and more involved than simply adding new toner. and the refill kits are a scam. Find a reliable supplier, and get a remanufactured unit with a guarantee, if you're looking to save money. Cartridges are designed to go 1 cycle, and then require a new drum, cleaning blade, doctor blade, bushings, toner, etc. The cartridge includes not only the toner supply unit, but also a waste section, that, even if you were to refill somewhat successfully, the section will begin to overflow, causing further problems. Cut your losses.
If you're local. I can help:
http://www.hotfrog.ca/Companies/Sandman-Sales-Service
Jan 18, 2009 | Canon X25 Toner Cartridge for imageCLASS...
Cant find old furnace filter for model # fguj080abn
The furnace model is irrelevant. The important question is usually the dimensions of the opening for the filters. The most common sizes are 16"x25"x1", 20"x25"x1", 16x25x5, etcetera. There are exceptions such as specialty filters like electronic ones. I suggest using inexpensive pleated filters but you could just use filters that you cut to fit instead. Have a helpful gasfitter assist you if necessary.
Dec 08, 2008 | Honeywell Power Humidifier: Furnace...
Navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Sep 20, 2008 | Navman F4100SX Fishfinder - W/ Transom...
Lowrance Hs Ws 50dbk Transom Mount Transducerdesc: 36 Degree 50 Khz Logo
358 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
