Question about TruTech PVS31170S1W 17 in. LCD Television
No audio when watching TV but do have audio when watching a DVD
No audio when watching TV but there is audio when watching DVD no audio period
  • TruTech Master
  • 19,396 Answers
To start unplug the tv from main for one hour or so, this will drain power and reset setting to factory, solving the problem if this is caused by incorrect TV audio settings.
If you use an external receiver to watch the TV, then the problem is either the connection cable to the receiver or a bad signal (input) board.
If instead you have the problem when the unit is set to the internal TV tuner, then responsible for the fault can be a faulty tuner board, or a faulty signal board, as the audio board inside this TV process in the same way if signal is coming from built in tuner or external device.
Posted on May 29, 2009
  • Ginko
    Ginko May 30, 2009
    Hi ,
    I tried to help with my free advice.
    I am sorry that your TV is faulty , but there is not much more I can do than telling you what possible faults can cause the possible faults and remedies.
    I will be grateful if you can change the negative rating given for the free advice.
    Many thanks.
    G.
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Don't have sound watching tv, but have sound when dvd
Download its user manual, and check audio settings. Refer it. If all settings are OK, still no sound output with on-air programmes, teh sound detector section has the fault. Seek tech support. This is a skilled work, and need all measuring instruments and through knowledge in electronics.
To download the user manual, click here.
Jun 06, 2012 | Apex Digital LD4088 LCD TV
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
Yamaha 5.1 says Check SP Cable and shuts down - has been fine.
It has nothing to do with the input you choose. A speaker wire is shorted. Disconnect each one in turn and try it. The last one disconnected before it stops failing is the one.
Mar 22, 2009 | Yamaha HTR-6030 Receiver
Speakers work only on DVD
You might have connected your TV/Stereo Receiver up to the wrong audio outputs of the DVD player. Make sure you are coming out of the FRONT left/right audio outputs and not the CENTER?REAR left/right audio outputs.
Mar 13, 2009 | Panasonic SB-TP55 System
Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Nov 05, 2008 | Denon AVR-1905 Receiver
How do I get surround sound from TV?
see if ur DVD player has a TV/Audio in....you have to set it up so u watch TV threw your DVD player (if you have one of of the Surround Sound in a box systems) if you have SS w/ a receiver then you'd have to run Audio out from your TV/Cable/Satellite to the receiver for it to work
Feb 02, 2008 | Jensen JHT805 System
Connecting VCR/DVD combo
Confusing! TV with NO yellow,red white input ? Buy an RF
adapter Radio Shack about 30.00.....TV has input ? = yellow
video,audio R,L from Insignia source dvd/vcr out ( audio R,L,
video {yellow} ) You don't need to switch cables.As to record
feature,consult owners manual..................................T
Nov 21, 2007 | Televison & Video
Receiver switches modes after a period of time
The actual switching is done by an electronic microprocessor. This electronic processor is most likely faulty by now, and needs to be replaced. Repair costs for this are expensive enough that buying a new receiver might be the best logical action, as a new comparable unit might cost only slightly more than the needed repair costs for the SA HE 200. Good luck.
Feb 26, 2007 | Panasonic SA-HE200 Receiver
TruTech PVS31170S1W 17 in. LCD Television Logo
279 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
